bootloader&wdt
FormerMember
FormerMember
hello everyone:
do you have try to add wdt into bootloader project?
i add it as follow: in the static void wait_for_events(void) function, i add two
if(NRF_WDT->RUNSTATUS&0x01){ NRF_WDT->RR[0]=WDT_RR_RR_Reload;}
    for (;;)
        // Wait in low power state for any events.
        uint32_t err_code = sd_app_evt_wait();
        // Event received. Process it from the scheduler.
        app_sched_execute();
        if ((m_update_status == BOOTLOADER_COMPLETE) ||
            (m_update_status == BOOTLOADER_TIMEOUT)  ||
            (m_update_status == BOOTLOADER_RESET))
            // When update has completed or a timeout/reset occured we will return.
            return;
and then,i try to DFU,when i send dfu command.it's time to wdt,it reset.
and before i add wdt to application.there i can dfu it nornal
is there anybody know the reason? can you tell me ? thank you
  • FormerMember
    0 FormerMember
    maybe it is not go in this function's If statement
  • You mean NRF_WDT->RUNSTATUS is not == 1 ? Could you run in debug mode or print out and check what value it is ?
  • i know in the SDK9.0,i can let it DFU by set the NRF_POWER->GPREGRET =BOOTLOADER_DFU_START(0xb1).and i want to use the same way in sdk12.3,but when i let NRF_POWER->GPREGRET =0xb1,it reset,and start application again,not in dfu mode ..and i test i really write the NRF_POWER->GPREGRET =0xb1,i printf it.(i use sdk12.3,nrf51822-QFAA),the reson is wdt.void
    wdt_timeout_handler(void * p_context)
    	nrf_gpio_pin_toggle(18);
    #define WDT_INTERVAL			           APP_TIMER_TICKS(1000,APP_TIMER_PRESCALER)
    APP_TIMER_DEF(wdt_timer_id);
    i test when i not open the wdt, it can dfu ok.the led can togle, means that the timer is work,and then, i open the wdt(#define WDT_CONFIG_RELOAD_VALUE 7000).and then ,wnen i set NRF_POWER->GPREGRET =BOOTLOADER_DFU_START,and then it retart after 7 seconds.do you know the reson ?can you tell me? thank you
  • Hi Yichen,
    If you reset the chip (in the application) by the watchdog reset, the GPREGRET register will be erased.
    You have two options:
    1 - Keep the WDT running, reset using soft reset. Then inside the bootloader you need to feed the dog.
    2 - Let the WDT trigger the reset , but then you need to write the flag to enter bootloader mode in flash instead of GPREGRET. This way you don't need to handle the WDT in the bootloader.
