Offset in SAADC samples with Easy DMA and BLE
I have a nrf52 application that samples four saadc channels at 1kHZ. That is: Map four pins to ADC input and let Easy DMA take care of the sampling so that the data is processed ten times a second (100 * 4 samples). This works pretty well, except...
When I enable the BLE connection, the data is shifted in the buffer. Without BLE enabled, the data layout in the memory is as following {{1,2,3,4}, {1,2,3,4}, ...}. But, when BLE is activated, the memory layout is: {{4,1,2,3}, {4,1,2,3}, ...} I really don't know what causes the difference. I have no way to check if the data is shifted, or did the samples just swap places. I wonder if the softdevice blocks some of the samples that would cause the problem.
The saadc implementation is double buffered, like in "saadc_sample_from_two_pins - scan mode" here
The BLE implementation is based on ble_app_hrs_freertos in SDK 12.1.0. That is also the SDK version I'm using.
Any help would be appreciated.
