for merge hex files
Hi. I'm using nRF51822AC, SDK12.2.0, S130 v2.0.1 as central.
I'm using mergehex for merging hex files. It's mergehex --merge s130_nrf51_2.0.1_softdevice.hex nrf51422_xxac.hex --output out.hex It has worked well.
But after I added bootloader_secure as below
mergehex --merge s130_nrf51_2.0.1_softdevice.hex nrf51422_xxac.hex bootloader_secure.hex --output out.hex
I faced a problem. I can download merged file to J-flash, but it can't download file to target.
I think it's memory map problem.
I'm using memory map as below.
App : IROM1 : Start :0x1B000 Size : 0x1FC00
Boot: IROM1 : Start :0x3AC00 Size : 0x5000
Is it right?
I need your help.
Ps. When I compile and execute bootloader, I can see the keil message as below.
No Algorithm found for: 10001014H - 10001017H Partial Erase Done (areas with no algorithms skipped!) No Algorithm found for: 10001014H - 10001017H Partial Programming Done (areas with no algorithms skipped!) Partial Verify OK (areas with no algorithms skipped!) Application running ...
I didn't care because code was running well.
