Eclipse GCC pure project for DFU Bootloader nRF51
I have created Eclipse project to compile nRF51 DFU loader. This is a pure Eclipse project, no makfile. It has compile configurations for combination of Single/Dual bank and BLE/Serial. This project require installed nRF51 SDK 5.2 in the same work space under with sdk directory name nrf51_sdk. The project has file links to the source in the sdk hence the sdk directory need to be that name. This will allow you to update to new sdk easier.
Here are the prerequisite.
Eclipse Keplar CDT Eclipse ARM plus ins: Follow this blog gnuarmeclipse.livius.net/.../. this contains support for jlink as well GCC compiler : launchpad.net/gcc-arm-embedded
Here are the attached files common.zip contains common folder to be place in same workspace. dfu_nrf51.zip is the project folder. It contains precompiled & tested hex release version of 4 binations if you don't want to recompile.
Workspace directory should have
Workspace | Common | dfu_nrf51 | nrf51_sdk
I hope this helps anyone who wants to work with Eclipse & GCC.
Good luck
Update sep. 18, 2014
Updated projects with sdk 6.1 on blog site here embeddedsoftdev.blogspot.ca/.../ehal-nrf51.html
  • If can help, with objdmp -h $build.hex
    /dfu_nrf51.hex: file format ihex
    Sections: Idx Name Size VMA LMA File off Algn 0 .sec1 0000336b 0003c800 0003c800 00000011 20 CONTENTS, ALLOC, LOAD 1 .sec2 00000040 0003fb6c 0003fb6c 000090b2 20 CONTENTS, ALLOC, LOAD 2 .sec3 00000400 0003fc00 0003fc00 00009173 20 CONTENTS, ALLOC, LOAD 3 .sec4 00000004 10001014 10001014 00009cd5 20 CONTENTS, ALLOC, LOAD
  • can you push this project to github ? it will be very, very useful to a lot of people.
