nrfConnect - DFU Option not shown but DFU Service is running
i try to use the nrfConnect (PC version) to update my devices via DFU. The DFU service is running on the device (update with Andoid nrfToolbox works without any problems). But the nrfConnect SW does not show the DFU Button. Whats going wrong?
Thanks!
  • I seems to be the bootloader on the device is started, the connection by MCP ist lost (due to invoking the bootloader) and there is no new connection establishment to the DFU device. Than i have try to connect to the already running DFU, but the connection is terminated during the service discovery. Perhaps it is better to convert this conversation to a support case? The benefit is, i can send you log - files or screen shots.
  • @AD1170: If there is no confidential info you can upload your log here by editing your question.
    I would need you to make sure you can use the MCP and nRF51DK without problem. Leave DFU aside, could you try to test any example in the SDK, ble_app_hrs for example, and keep them connected for a few minutes.
    " the connection is terminated during the service discovery" => Please attach log.
    Please try to test with just the DFU bootloader, don't flash your application. Try to do a DFU with application image from one of our example.
    Which SDK are you using ? We don't have SDK v8.9.
  • I can connect with the MCP to my application, service dicovery works and the connection is hold for any time. Is this statement sufficent or should i try to connet to your hrm example.
  • Here is the last part of the Log file when i try the FW download:
        1530;16:12:26.3167 [681093730][MainThread] Connecting
    1531;16:12:26.3437 [681093730][MainThread] Enter Connect
    1532;16:12:26.3487 [681093730][MainThread] TST-Client: Sending Create LL connection to D26DC4210772
    1533;16:12:26.3687 [681093730][MainThread] HCI command: BTLE_CMD_LE_CREATE_CONNECTION, ConnIntervalMin: 20ms, ConnIntervalMax: 20ms, SupervisionTimeout: 3000ms, PeerAddress: 0x72-07-21-C4-6D-D2, PeerAddressType: BTLE_ADDR_TYPE_RANDOM, OwnAddressType: BTLE_ADDR_TYPE_PUBLIC, ConnLatency: 0, ScanInterval: 250ms, ScanWindow: 200ms, FilterPolicy: BTLE_INITIATOR_FILTER_SKIP_WHITELIST, MinCeLength: 160, MaxCeLength: 160
    1534;16:12:26.3697 [681093730][MainThread] Serial port write: 01-0D-20-19-90-01-40-01-00-01-72-07-21-C4-6D-D2-00-10-00-10-00-00-00-2C-01-A0-00-A0-00
    1535;16:12:26.3717 [681093730][ReadPacketQueueThread] Serial port read: 04-0F-04-00-01-0D-20
    1536;16:12:26.3717 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_STATUS, OpCode: BTLE_CMD_LE_CREATE_CONNECTION, Status: BTLE_STATUS_CODE_SUCCESS
    1537;16:12:26.3817 [681093730][ReadPacketQueueThread] Serial port read: 04-3E-13-01-00-00-00-00-01-72-07-21-C4-6D-D2-10-00-00-00-2C-01-01
    1538;16:12:26.3817 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_LE_CONNECTION_COMPLETE, Status: BTLE_STATUS_CODE_SUCCESS, ConnectionHandle: 0x0000, Role: BTLE_CONNECTION_ROLE_MASTER, AddressType: BTLE_ADDR_TYPE_RANDOM, PeerAddress: 0xD26DC4210772, ConnectionInterval: 20ms, Latency: 0, Timeout: 3000ms, ClockAccuracy: BTLE_CLOCK_ACCURACY_250_PPM
    1539;16:12:26.3857 [681093730][MainThread] TST-Client: Waiting for LL Connection Created Event
    1540;16:12:26.4007 [681093730][MainThread] TST-Client: Connection created successful. ConnectionId: 0
    1541;16:12:26.4097 [681093730][MainThread] ----------------------------
    Connected to device
    Connection Interval: 20ms
    Connection Latency: 0
    Supervision Timeout: 3000ms
    1542;16:12:26.4097 [681093730][MainThread] [16:12:26.409] [Emulator] Connected to D26DC4210772
    1543;16:12:26.4097 [681093730][MainThread] Connected to D26DC4210772
    1544;16:12:26.4117 [681093730][ReadPacketQueueThread] [16:12:26.411] Connected to peer device
    1545;16:12:26.4357 [681093730][MainThread] [16:12:26.435] --- Connected ---
    1546;16:12:26.4447 [681093730][MainThread] [16:12:26.444] [Emulator] Discover pipes
    1547;16:12:26.4447 [681093730][MainThread] Discover pipes
    1548;16:12:26.4517 [681093730][] SERVER: Received packet <HciEvent: eventCode=0x05> - <HciEvent: eventCode=0x05>
    1549;16:12:26.4607 [681093730][] DeviceDiscovered worker completed
    1550;16:12:26.4787 [681093730][MainThread] GATT: Discovering all Primary Services of type 0x15301212EFDE1523785FEABCD123
    1551;16:12:26.4827 [681093730][MainThread] GATT: Sending Find By Type Value Request, start handle 0x0001
    1552;16:12:26.5167 [681093730][MainThread] WRITE DATA PACKET:17-00-04-00-06-01-00-FF-FF-00-28-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-30-15-00-00
    1553;16:12:26.5177 [681093730][MainThread] Sending packet: AttFindByTypeValueRequest, 06-01-00-FF-FF-00-28-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-30-15-00-00, StartHandle: 0x0001, EndHandle: 0xFFFF, AttributeType: 0x2800, AttributeValue: 23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-30-15-00-00
    1554;16:12:26.5177 [681093730][MainThread] Serial port write: 02-00-00-1B-00-17-00-04-00-06-01-00-FF-FF-00-28-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-30-15-00-00
    1555;16:12:26.5177 [681093730][MainThread] Data buffer queue length (+1): 1
    1556;16:12:26.5177 [681093730][MainThread] Number of data packets sent: 1
    1557;16:12:26.5257 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1558;16:12:26.5257 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1559;16:12:26.5257 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1560;16:12:26.5437 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-09-00-05-00-04-00-07-2E-00-FF-FF
    1561;16:12:26.5457 [681093730][ReadPacketQueueThread] Received packet: AttFindByTypeValueResponse, 07-2E-00-FF-FF, FoundAttributeHandle: 0x002E, GroupEndHandle: 0xFFFF
    1562;16:12:26.6047 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttFindByTypeValueResponse'> - [0x07, 0x2E, 0x00, 0xFF, 0xFF]
    1563;16:12:26.6047 [681093730][MainThread] GATT: Received Find By Type Value Response
    1564;16:12:26.6047 [681093730][MainThread] GATT: Found Service handle start 0x002E and end 0xFFFF
    1565;16:12:26.6527 [681093730][MainThread] GATT: Discovering all Characteristics of service 0x15301212EFDE1523785FEABCD123
    1566;16:12:26.6527 [681093730][MainThread] GATT: Sending Read By Type Request, start handle 0x002F
    1567;16:12:26.6667 [681093730][MainThread] WRITE DATA PACKET:07-00-04-00-08-2F-00-FF-FF-03-28
    1568;16:12:26.6677 [681093730][MainThread] Sending packet: AttReadByTypeRequest, 08-2F-00-FF-FF-03-28, StartHandle: 0x002F, EndHandle: 0xFFFF, AttributeType: 0x2803
    1569;16:12:26.6677 [681093730][MainThread] Serial port write: 02-00-00-0B-00-07-00-04-00-08-2F-00-FF-FF-03-28
    1570;16:12:26.6677 [681093730][MainThread] Data buffer queue length (+1): 1
    1571;16:12:26.6677 [681093730][MainThread] Number of data packets sent: 2
    1572;16:12:26.7037 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1573;16:12:26.7037 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1574;16:12:26.7037 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1575;16:12:26.7237 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-1B-00-17-00-04-00-09-15-2F-00-04-30-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-32-15-00-00
    1576;16:12:26.7257 [681093730][ReadPacketQueueThread] Received packet: AttReadByTypeResponse, 09-15-2F-00-04-30-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-32-15-00-00, Length: 21, Handle: 0x002F, Value: 04-30-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-32-15-00-00
    1577;16:12:26.7477 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttReadByTypeResponse'> - [0x09, 0x15, 0x2F, 0x00, 0x04, 0x30, 0x00, 0x23, 0xD1, 0xBC, 0xEA, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x32, 0x15, 0x00, 0x00]
    1578;16:12:26.7477 [681093730][MainThread] GATT: Received Read By Type Response
    1579;16:12:26.7677 [681093730][MainThread] GATT: Sending Read By Type Request, start handle 0x0030
    1580;16:12:26.7687 [681093730][MainThread] WRITE DATA PACKET:07-00-04-00-08-30-00-FF-FF-03-28
    1581;16:12:26.7687 [681093730][MainThread] Sending packet: AttReadByTypeRequest, 08-30-00-FF-FF-03-28, StartHandle: 0x0030, EndHandle: 0xFFFF, AttributeType: 0x2803
    1582;16:12:26.7687 [681093730][MainThread] Serial port write: 02-00-00-0B-00-07-00-04-00-08-30-00-FF-FF-03-28
    1583;16:12:26.7687 [681093730][MainThread] Data buffer queue length (+1): 1
    1584;16:12:26.7687 [681093730][MainThread] Number of data packets sent: 3
    1585;16:12:26.7837 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1586;16:12:26.7837 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1587;16:12:26.7837 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1588;16:12:26.8037 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-1B-00-17-00-04-00-09-15-31-00-18-32-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-31-15-00-00
    1589;16:12:26.8037 [681093730][ReadPacketQueueThread] Received packet: AttReadByTypeResponse, 09-15-31-00-18-32-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-31-15-00-00, Length: 21, Handle: 0x0031, Value: 18-32-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-31-15-00-00
    1590;16:12:26.8067 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttReadByTypeResponse'> - [0x09, 0x15, 0x31, 0x00, 0x18, 0x32, 0x00, 0x23, 0xD1, 0xBC, 0xEA, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x31, 0x15, 0x00, 0x00]
    1591;16:12:26.8067 [681093730][MainThread] GATT: Received Read By Type Response
    1592;16:12:26.8067 [681093730][MainThread] GATT: Sending Read By Type Request, start handle 0x0032
    1593;16:12:26.8067 [681093730][MainThread] WRITE DATA PACKET:07-00-04-00-08-32-00-FF-FF-03-28
    1594;16:12:26.8067 [681093730][MainThread] Sending packet: AttReadByTypeRequest, 08-32-00-FF-FF-03-28, StartHandle: 0x0032, EndHandle: 0xFFFF, AttributeType: 0x2803
    1595;16:12:26.8067 [681093730][MainThread] Serial port write: 02-00-00-0B-00-07-00-04-00-08-32-00-FF-FF-03-28
    1596;16:12:26.8067 [681093730][MainThread] Data buffer queue length (+1): 1
    1597;16:12:26.8067 [681093730][MainThread] Number of data packets sent: 4
    1598;16:12:26.8237 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1599;16:12:26.8237 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1600;16:12:26.8237 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1601;16:12:26.8437 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-1B-00-17-00-04-00-09-15-34-00-02-35-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-34-15-00-00
    1602;16:12:26.8437 [681093730][ReadPacketQueueThread] Received packet: AttReadByTypeResponse, 09-15-34-00-02-35-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-34-15-00-00, Length: 21, Handle: 0x0034, Value: 02-35-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-34-15-00-00
    1603;16:12:26.8527 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttReadByTypeResponse'> - [0x09, 0x15, 0x34, 0x00, 0x02, 0x35, 0x00, 0x23, 0xD1, 0xBC, 0xEA, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x34, 0x15, 0x00, 0x00]
    1604;16:12:26.8527 [681093730][MainThread] GATT: Received Read By Type Response
    1605;16:12:26.8527 [681093730][MainThread] GATT: Sending Read By Type Request, start handle 0x0035
    1606;16:12:26.8527 [681093730][MainThread] WRITE DATA PACKET:07-00-04-00-08-35-00-FF-FF-03-28
    1607;16:12:26.8527 [681093730][MainThread] Sending packet: AttReadByTypeRequest, 08-35-00-FF-FF-03-28, StartHandle: 0x0035, EndHandle: 0xFFFF, AttributeType: 0x2803
    1608;16:12:26.8527 [681093730][MainThread] Serial port write: 02-00-00-0B-00-07-00-04-00-08-35-00-FF-FF-03-28
    1609;16:12:26.8527 [681093730][MainThread] Data buffer queue length (+1): 1
    1610;16:12:26.8527 [681093730][MainThread] Number of data packets sent: 5
    1611;16:12:26.8637 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1612;16:12:26.8637 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1613;16:12:26.8637 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1614;16:12:26.8837 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-09-00-05-00-04-00-01-08-35-00-0A
    1615;16:12:26.8837 [681093730][ReadPacketQueueThread] Received packet: AttErrorResponse, 01-08-35-00-0A, OpCode: ReadByTypeRequest, Handle: 0x0035, ErrorCode: AttributeNotFound
    1616;16:12:26.8997 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttErrorResponse'> - [0x01, 0x08, 0x35, 0x00, 0x0A]
    1617;16:12:26.9007 [681093730][MainThread] GATT: Received Error Response on handle 0x0035 reason 0x0A
    1618;16:12:26.9197 [681093730][MainThread] Found characteristic with matching uuid (0x15321212EFDE1523785FEABCD123)
    1619;16:12:26.9207 [681093730][MainThread] [16:12:26.920] [Emulator] Discovered pipe 1 (characteristic 0x15321212EFDE1523785FEABCD123, service 0x15301212EFDE1523785FEABCD123)
    1620;16:12:26.9207 [681093730][MainThread] Discovered pipe 1 (characteristic 0x15321212EFDE1523785FEABCD123, service 0x15301212EFDE1523785FEABCD123)
    1621;16:12:26.9227 [681093730][MainThread] Found characteristic with matching uuid (0x15311212EFDE1523785FEABCD123)
    1622;16:12:26.9227 [681093730][MainThread] [16:12:26.922] [Emulator] Discovered pipe 2 (characteristic 0x15311212EFDE1523785FEABCD123, service 0x15301212EFDE1523785FEABCD123)
    1623;16:12:26.9227 [681093730][MainThread] Discovered pipe 2 (characteristic 0x15311212EFDE1523785FEABCD123, service 0x15301212EFDE1523785FEABCD123)
    1624;16:12:26.9227 [681093730][MainThread] Found characteristic with matching uuid (0x15311212EFDE1523785FEABCD123)
    1625;16:12:26.9237 [681093730][MainThread] [16:12:26.923] [Emulator] Discovered pipe 3 (characteristic 0x15311212EFDE1523785FEABCD123, service 0x15301212EFDE1523785FEABCD123)
    1626;16:12:26.9237 [681093730][MainThread] Discovered pipe 3 (characteristic 0x15311212EFDE1523785FEABCD123, service 0x15301212EFDE1523785FEABCD123)
    1627;16:12:26.9317 [681093730][MainThread] GATT: Discovering all the Descriptors of Characteristic 0x15311212EFDE1523785FEABCD123, start handle 0x0033, end handle 0x0033
    1628;16:12:26.9317 [681093730][MainThread] GATT: Sending Find Information Request, start handle 0x0033
    1629;16:12:26.9377 [681093730][MainThread] WRITE DATA PACKET:05-00-04-00-04-33-00-33-00
    1630;16:12:26.9377 [681093730][MainThread] Sending packet: AttFindInformationRequest, 04-33-00-33-00, StartHandle: 0x0033, EndHandle: 0x0033
    1631;16:12:26.9377 [681093730][MainThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-33-00-33-00
    1632;16:12:26.9377 [681093730][MainThread] Data buffer queue length (+1): 1
    1633;16:12:26.9377 [681093730][MainThread] Number of data packets sent: 6
    1634;16:12:26.9637 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1635;16:12:26.9637 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1636;16:12:26.9637 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1637;16:12:26.9837 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0A-00-06-00-04-00-05-01-33-00-02-29
    1638;16:12:26.9837 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-01-33-00-02-29, Format: HandleAnd16BitUuid, Handle: 0x0033, Uuid: 0x2902
    1639;16:12:27.0007 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttFindInformationResponse'> - [0x05, 0x01, 0x33, 0x00, 0x02, 0x29]
    1640;16:12:27.0007 [681093730][MainThread] GATT: Received Find Information Response
    1641;16:12:27.0007 [681093730][MainThread] GATT: Found Descriptor 0x2902 on handle 0x0033
    1642;16:12:27.0127 [681093730][MainThread] GATT: Sending Read Request on Characteristic descriptor 0x2902 on handle=0033
    1643;16:12:27.0167 [681093730][MainThread] WRITE DATA PACKET:03-00-04-00-0A-33-00
    1644;16:12:27.0167 [681093730][MainThread] Sending packet: AttReadRequest, 0A-33-00, Handle: 0x0033
    1645;16:12:27.0167 [681093730][MainThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-33-00
    1646;16:12:27.0167 [681093730][MainThread] Data buffer queue length (+1): 1
    1647;16:12:27.0167 [681093730][MainThread] Number of data packets sent: 7
    1648;16:12:27.0217 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1649;16:12:27.0217 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1650;16:12:27.0217 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1651;16:12:27.0437 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-07-00-03-00-04-00-0B-00-00
    1652;16:12:27.0437 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-00-00, AttributeValue: 00-00
    1653;16:12:27.0567 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttReadResponse'> - [0x0B, 0x00, 0x00]
    1654;16:12:27.0567 [681093730][MainThread] GATT: Received Read Response
    1655;16:12:27.0617 [681093730][MainThread] [16:12:27.061] [Emulator] Discovered pipe 3 CCCD (descriptor 0x2902, service 0x15301212EFDE1523785FEABCD123)
    1656;16:12:27.0617 [681093730][MainThread] Discovered pipe 3 CCCD (descriptor 0x2902, service 0x15301212EFDE1523785FEABCD123)
    1657;16:12:27.0637 [681093730][MainThread] Pipe setup after pipe discovery:
    1658;16:12:27.0677 [681093730][MainThread] 1: {'descriptor_info': None, 'pipe_store': 2, 'handle': 48, 'service_id': 1, 'parent_service_uuid': 429739147100953594165605640753443L, 'cccd_handle': None, 'pipe_uuid': 429897603425982122840792728654115L, 'pipe_type': 2, 'parent_service_handle': None, 'char_properties': 4, 'char_id': 1, 'parent_char_uuid': None, 'namespace_description': None}
    1659;16:12:27.0677 [681093730][MainThread] 2: {'descriptor_info': None, 'pipe_store': 2, 'handle': 50, 'service_id': 1, 'parent_service_uuid': 429739147100953594165605640753443L, 'cccd_handle': None, 'pipe_uuid': 429818375263467858503199184703779L, 'pipe_type': 4, 'parent_service_handle': None, 'char_properties': 24, 'char_id': 2, 'parent_char_uuid': None, 'namespace_description': None}
    1660;16:12:27.0677 [681093730][MainThread] 3: {'descriptor_info': None, 'pipe_store': 2, 'handle': 50, 'service_id': 1, 'parent_service_uuid': 429739147100953594165605640753443L, 'cccd_handle': 51, 'pipe_uuid': 429818375263467858503199184703779L, 'pipe_type': 8, 'parent_service_handle': None, 'char_properties': 24, 'char_id': 2, 'parent_char_uuid': None, 'namespace_description': None}
    1661;16:12:27.0677 [681093730][MainThread] PIPES RETURN VALUE: True
    1662;16:12:27.0677 [681093730][MainThread] [16:12:27.067] --- Pipes discovered ---
    1663;16:12:27.0897 [681093730][MainThread] [16:12:27.089] [Emulator] Opening pipe 3
    1664;16:12:27.0897 [681093730][MainThread] Opening pipe 3
    1665;16:12:27.0907 [681093730][MainThread] GATT: Sending Read Request on Characteristic descriptor 0x2902 on handle=0033
    1666;16:12:27.0907 [681093730][MainThread] WRITE DATA PACKET:03-00-04-00-0A-33-00
    1667;16:12:27.0907 [681093730][MainThread] Sending packet: AttReadRequest, 0A-33-00, Handle: 0x0033
    1668;16:12:27.0917 [681093730][MainThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-33-00
    1669;16:12:27.0917 [681093730][MainThread] Data buffer queue length (+1): 1
    1670;16:12:27.0917 [681093730][MainThread] Number of data packets sent: 8
    1671;16:12:27.1037 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1672;16:12:27.1037 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1673;16:12:27.1037 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1674;16:12:27.1237 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-07-00-03-00-04-00-0B-00-00
    1675;16:12:27.1237 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-00-00, AttributeValue: 00-00
    1676;16:12:27.1377 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttReadResponse'> - [0x0B, 0x00, 0x00]
    1677;16:12:27.1377 [681093730][MainThread] GATT: Received Read Response
    1678;16:12:27.1427 [681093730][MainThread] GATT: Sending Write Request on Characteristic descriptor 0x2902 on handle=0033
    1679;16:12:27.1477 [681093730][MainThread] WRITE DATA PACKET:05-00-04-00-12-33-00-01-00
    1680;16:12:27.1477 [681093730][MainThread] Sending packet: AttWriteRequest, 12-33-00-01-00, Handle: 0x0033, Value: 01-00
    1681;16:12:27.1477 [681093730][MainThread] Serial port write: 02-00-00-09-00-05-00-04-00-12-33-00-01-00
    1682;16:12:27.1477 [681093730][MainThread] Data buffer queue length (+1): 1
    1683;16:12:27.1477 [681093730][MainThread] Number of data packets sent: 9
    1684;16:12:27.1637 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1685;16:12:27.1637 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1686;16:12:27.1637 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1687;16:12:27.2037 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-05-00-01-00-04-00-13
    1688;16:12:27.2047 [681093730][ReadPacketQueueThread] Received packet: AttWriteResponse, 13
    1689;16:12:27.2117 [681093730][MainThread] GATT: Received <class 'protocol.Att.AttWriteResponse'> - [0x13]
    1690;16:12:27.2117 [681093730][MainThread] GATT: Att Write Response
    1691;16:12:27.2567 [681093730][MainThread] Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 86816
    1692;16:12:27.2587 [681093730][MainThread] Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
    1693;16:12:27.2727 [681093730][MainThread] Sending 'START DFU' command
    1694;16:12:27.3077 [681093730][MainThread] GATT: Sending Write Request on Characteristic Value uuid 0x15311212EFDE1523785FEABCD123 on handle=0032
    1695;16:12:27.3077 [681093730][MainThread] WRITE DATA PACKET:05-00-04-00-12-32-00-01-04
    1696;16:12:27.3077 [681093730][MainThread] Sending packet: AttWriteRequest, 12-32-00-01-04, Handle: 0x0032, Value: 01-04
    1697;16:12:27.3077 [681093730][MainThread] Serial port write: 02-00-00-09-00-05-00-04-00-12-32-00-01-04
    1698;16:12:27.3077 [681093730][MainThread] Data buffer queue length (+1): 1
    1699;16:12:27.3077 [681093730][MainThread] Number of data packets sent: 10
    1700;16:12:27.3237 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    1701;16:12:27.3237 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    1702;16:12:27.3237 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    1703;16:12:30.3419 [681093730][ReadPacketQueueThread] Serial port read: 04-05-04-00-00-00-08
    1704;16:12:30.3429 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_DISCONNECTION_COMPLETE ConnectionHandle: 0x0000, Reason: BTLE_CONNECTION_TIMEOUT
    1705;16:12:30.3519 [681093730][ReadPacketQueueThread] Received LL Connection Termination Event, reason 08
    1706;16:12:30.3539 [681093730][ReadPacketQueueThread] Lost connection to device
    1707;16:12:30.3609 [681093730][ReadPacketQueueThread] [16:12:30.360] Disconnected from peer device
    1708;16:12:30.3669 [681093730][ReadPacketQueueThread] Device disconnected, reason: ConnectionTimeout
    1709;16:12:30.3949 [681093730][] SERVER: Received packet <HciEvent: eventCode=0x0A> - <HciEvent: eventCode=0x0A>
    1710;16:12:30.3949 [681093730][] SERVER: Received Link Loss
    1711;16:12:30.4029 [681093730][MainThread] Wait canceled: no connection.
    1712;16:12:30.4029 [681093730][MainThread] GATT: Received None - None
    1713;16:12:30.4049 [681093730][MainThread] [16:12:30.404] [Emulator] Failed to send data on pipe number 2
    1714;16:12:30.4049 [681093730][MainThread] Failed to send data on pipe number 2
    1715;16:12:30.4929 [681093730][MainThread] Data could not be sent - failed!
    1716;16:12:31.4989 [681093730][MainThread] [16:12:31.498] Not connected - Skipping
    1717;16:12:31.5069 [681093730][MainThread] SERVER: Stopping server
    1718;16:12:31.5079 [681093730][MainThread] [16:12:31.507] [Emulator] Close
    1719;16:12:31.5079 [681093730][MainThread] Close
    1720;16:12:31.5109 [681093730][MainThread] HciH4Driver closed
    1721;16:12:32.3990 [681093730][] SERVER: Server has stopped
    1722;16:12:45.5207 [681093730][MainThread] nrfjprog.dll 5.2.0.45231
    1723;16:12:45.5237 [681093730][MainThread] HciJLinkDriver opened (COM11, 1000000-8-None-1-RequestToSend)
    1724;16:12:45.5257 [681093730][MainThread] JLinkARM.dll 5.12g
    1725;16:12:45.5368 [681093730][MainThread] 681093730 - COM11
    1726;16:12:46.6668 [681093730][MainThread] HCI command: BTLE_CMD_READ_BD_ADDR
    1727;16:12:46.6668 [681093730][MainThread] Serial port write: 01-09-10-00
    1728;16:12:46.6668 [681093730][MainThread] Waiting for event packet. Timeout is 500ms
    1729;16:12:46.6728 [681093730][ReadPacketQueueThread] Serial port read: 04-0E-0A-01-09-10-00-56-FF-99-00-CD-29
    1730;16:12:46.6728 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: BTLE_CMD_READ_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS, BdAddress: 0x29CD0099FF56
    1731;16:12:46.6728 [681093730][MainThread] Finished waiting for event packet. PacketReceived:True
    1732;16:12:46.6738 [681093730][MainThread] HCI command: NRF_CMD_SET_BD_ADDR, Address: 0x40-27-06-BC-8B-5A
    1733;16:12:46.6738 [681093730][MainThread] Serial port write: 01-03-FC-06-40-27-06-BC-8B-5A
    1734;16:12:46.6738 [681093730][MainThread] Waiting for event packet. Timeout is 500ms
    1735;16:12:46.6768 [681093730][ReadPacketQueueThread] Serial port read: 04-0E-04-01-03-FC-00
    1736;16:12:46.6768 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: NRF_CMD_SET_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS
    1737;16:12:46.6768 [681093730][MainThread] Finished waiting for event packet. PacketReceived:True
    1738;16:12:46.6768 [681093730][MainThread] HCI command: NRF_CMD_GET_VERSION_INFO
    1739;16:12:46.6768 [681093730][MainThread] Serial port write: 01-06-FC-00
    1740;16:12:46.6768 [681093730][MainThread] Waiting for event packet. Timeout is 500ms
    1741;16:12:46.6808 [681093730][ReadPacketQueueThread] Serial port read: 04-0E-2C-01-06-FC-00-6D-65-66-77-5F-6E-72-66-35-31-38-32-32-5F-30-2E-31-31-2E-30-2E-31-38-33-37-38-00-00-00-00-00-00-00-00-00-00-00-00-00-00
    1742;16:12:46.6808 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: NRF_CMD_GET_VERSION_INFO, Status: BTLE_STATUS_CODE_SUCCESS, VersionInfo: mefw_nrf51822_0.11.0.18378
    1743;16:12:46.6808 [681093730][MainThread] Finished waiting for event packet. PacketReceived:True
    1744;16:12:47.2218 [681093730][ScriptThread] Failed to import ecdsa, cannot do signing
    1745;16:12:47.2448 [681093730][ScriptThread]  - - Start of script: (2017-03-22 15:12:47) - -
    1746;16:12:47.2778 [681093730][ScriptThread] HCI command: BTLE_CMD_READ_BD_ADDR
    1747;16:12:47.2788 [681093730][ScriptThread] Serial port write: 01-09-10-00
    1748;16:12:47.2969 [681093730][ReadPacketQueueThread] Serial port read: 04-0E-0A-01-09-10-00-40-27-06-BC-8B-5A
    1749;16:12:47.2969 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: BTLE_CMD_READ_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS, BdAddress: 0x5A8BBC062740
    1750;16:12:47.3559 [681093730][ScriptThread] Device address: 0x5A8BBC062740
    1751;16:12:47.3569 [681093730][ScriptThread] Ready
    1752;16:12:47.4199 [681093730][] Successfully parsed the server setup:
    1: R_PERM:yes NOTIFY:no UUID:0x2800 W_PERM:no INDICATE:no DATA:0x[0, 18]
    2: R_PERM:yes NOTIFY:no UUID:0x2803 W_PERM:no INDICATE:no DATA:0x[6, 3, 0, 0, 2A]
    3: R_PERM:yes NOTIFY:no UUID:0x2A00 W_PERM:yes INDICATE:no DATA:0x[4D, 61, 73, 74, 65, 72, 20, 43, 6F, 6E, 74, 72, 6F, 6C, 20, 50, 61, 6E, 65, 6C]
    4: R_PERM:yes NOTIFY:no UUID:0x2800 W_PERM:no INDICATE:no DATA:0x[1, 18]
    1753;16:12:47.4199 [681093730][] CreateServerFromObject()
    1754;16:12:47.4499 [681093730][] Starting Server
    1755;16:12:47.5349 [681093730][] SERVER: Server has started
    1756;16:12:47.5539 [681093730][MainThread] ServerStartupWorker completed
  • Here is the part of the log file where i connect to the alredy running bootloader on the device. The service discovery works but the DFU button is still disabled. Until i not discover the services, the connection is hold. After di
    covering the services, the connection is terminted (the device perform a restart).
        3088;16:22:15.8114 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_LE_ADVERTISING_REPORT, EventType: BTLE_REPORT_TYPE_SCAN_RSP, AddressType: BTLE_ADDR_TYPE_RANDOM, DeviceAddress: 0xD26DC4210772, RSSI: -43dBm, DataLength: 0, Data:
    3089;16:22:15.8224 [681093730][MainThread] HCI command: BTLE_CMD_LE_SET_SCAN_ENABLE, ScanMode: BTLE_SCAN_MODE_DISABLE, FilterMode: BTLE_SCAN_DUPLICATE_FILTER_DISABLE
    3090;16:22:15.8224 [681093730][MainThread] Serial port write: 01-0C-20-02-00-00
    3091;16:22:15.8224 [681093730][MainThread] Waiting for event packet. Timeout is 500ms
    3092;16:22:15.8254 [681093730][ReadPacketQueueThread] Serial port read: 04-0E-04-01-0C-20-00
    3093;16:22:15.8254 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: BTLE_CMD_LE_SET_SCAN_ENABLE, Status: BTLE_STATUS_CODE_SUCCESS
    3094;16:22:15.8254 [681093730][MainThread] Finished waiting for event packet. PacketReceived:True
    3095;16:22:17.1174 [681093730][MainThread] ConnectToDevice(peerAddress="720721C46DD2",addressTypePeer=1,scanInterval=400,scanWindow=320,connIntervalMin=16,connIntervalMax=16,connLatency=0,connTimeout=300)
    3096;16:22:17.1244 [681093730][ScriptMethodCallThread] Enter Connect
    3097;16:22:17.1294 [681093730][ScriptMethodCallThread] TST-Client: Sending Create LL connection to D26DC4210772
    3098;16:22:17.1424 [681093730][ScriptMethodCallThread] HCI command: BTLE_CMD_LE_CREATE_CONNECTION, ConnIntervalMin: 20ms, ConnIntervalMax: 20ms, SupervisionTimeout: 3000ms, PeerAddress: 0x72-07-21-C4-6D-D2, PeerAddressType: BTLE_ADDR_TYPE_RANDOM, OwnAddressType: BTLE_ADDR_TYPE_PUBLIC, ConnLatency: 0, ScanInterval: 250ms, ScanWindow: 200ms, FilterPolicy: BTLE_INITIATOR_FILTER_SKIP_WHITELIST, MinCeLength: 160, MaxCeLength: 160
    3099;16:22:17.1424 [681093730][ScriptMethodCallThread] Serial port write: 01-0D-20-19-90-01-40-01-00-01-72-07-21-C4-6D-D2-00-10-00-10-00-00-00-2C-01-A0-00-A0-00
    3100;16:22:17.1464 [681093730][ReadPacketQueueThread] Serial port read: 04-0F-04-00-01-0D-20
    3101;16:22:17.1464 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_STATUS, OpCode: BTLE_CMD_LE_CREATE_CONNECTION, Status: BTLE_STATUS_CODE_SUCCESS
    3102;16:22:17.1624 [681093730][ScriptMethodCallThread] TST-Client: Waiting for LL Connection Created Event
    3103;16:22:17.1754 [681093730][ReadPacketQueueThread] Serial port read: 04-3E-13-01-00-00-00-00-01-72-07-21-C4-6D-D2-10-00-00-00-2C-01-01
    3104;16:22:17.1754 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_LE_CONNECTION_COMPLETE, Status: BTLE_STATUS_CODE_SUCCESS, ConnectionHandle: 0x0000, Role: BTLE_CONNECTION_ROLE_MASTER, AddressType: BTLE_ADDR_TYPE_RANDOM, PeerAddress: 0xD26DC4210772, ConnectionInterval: 20ms, Latency: 0, Timeout: 3000ms, ClockAccuracy: BTLE_CLOCK_ACCURACY_250_PPM
    3105;16:22:17.1964 [681093730][ScriptMethodCallThread] TST-Client: Connection created successful. ConnectionId: 0
    3106;16:22:17.2024 [681093730][ScriptMethodCallThread] ----------------------------
    3107;16:22:17.2024 [681093730][ScriptMethodCallThread] Connected to device
    3108;16:22:17.2034 [681093730][ScriptMethodCallThread] Role: 0
    3109;16:22:17.2044 [681093730][ScriptMethodCallThread] PeerAddressType: 1
    3110;16:22:17.2044 [681093730][ScriptMethodCallThread] PeerAddress (MSB): D26DC4210772
    3111;16:22:17.2044 [681093730][ScriptMethodCallThread] Connection Interval: 20.0ms
    3112;16:22:17.2054 [681093730][ScriptMethodCallThread] Connection Latency: 0
    3113;16:22:17.2054 [681093730][ScriptMethodCallThread] Supervision Timeout: 3000ms
    3114;16:22:17.2064 [681093730][ScriptMethodCallThread] Clock Accuracy: (1)
    3115;16:22:17.2064 [681093730][ScriptMethodCallThread] ----------------------------
    3116;16:22:17.2064 [681093730][ScriptMethodCallThread] Connected to D26DC4210772
    3117;16:22:17.2124 [681093730][] SERVER: Received packet <HciEvent: eventCode=0x05> - <HciEvent: eventCode=0x05>
    3118;16:22:19.8536 [681093730][MainThread] GetDeviceInfo(peerAddress="720721C46DD2",addressTypePeer=1,scanInterval=400,scanWindow=320,connIntervalMin=16,connIntervalMax=16,connLatency=0,connTimeout=300)
    3119;16:22:19.8566 [681093730][ScriptMethodCallThread] Starting a Read Information Request on the whole remote DB
    3120;16:22:19.8766 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-01-00-FF-FF
    3121;16:22:19.8766 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-01-00-FF-FF, StartHandle: 0x0001, EndHandle: 0xFFFF
    3122;16:22:19.8766 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-01-00-FF-FF
    3123;16:22:19.8766 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3124;16:22:19.8766 [681093730][ScriptMethodCallThread] Number of data packets sent: 1
    3125;16:22:19.8956 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3126;16:22:19.8956 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3127;16:22:19.8956 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3128;16:22:19.9156 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-1A-00-16-00-04-00-05-01-01-00-00-28-02-00-03-28-03-00-00-2A-04-00-03-28-05-00-01-2A
    3129;16:22:19.9156 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-01-01-00-00-28-02-00-03-28-03-00-00-2A-04-00-03-28-05-00-01-2A, Format: HandleAnd16BitUuid, Handle: 0x0001, Uuid: 0x2800, Handle: 0x0002, Uuid: 0x2803, Handle: 0x0003, Uuid: 0x2A00, Handle: 0x0004, Uuid: 0x2803, Handle: 0x0005, Uuid: 0x2A01
    3130;16:22:19.9796 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-06-00-FF-FF
    3131;16:22:19.9796 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-06-00-FF-FF, StartHandle: 0x0006, EndHandle: 0xFFFF
    3132;16:22:19.9796 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-06-00-FF-FF
    3133;16:22:19.9796 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3134;16:22:19.9796 [681093730][ScriptMethodCallThread] Number of data packets sent: 2
    3135;16:22:19.9956 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3136;16:22:19.9956 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3137;16:22:19.9956 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3138;16:22:20.0176 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-1A-00-16-00-04-00-05-01-06-00-03-28-07-00-04-2A-08-00-00-28-09-00-03-28-0A-00-05-2A
    3139;16:22:20.0176 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-01-06-00-03-28-07-00-04-2A-08-00-00-28-09-00-03-28-0A-00-05-2A, Format: HandleAnd16BitUuid, Handle: 0x0006, Uuid: 0x2803, Handle: 0x0007, Uuid: 0x2A04, Handle: 0x0008, Uuid: 0x2800, Handle: 0x0009, Uuid: 0x2803, Handle: 0x000A, Uuid: 0x2A05
    3140;16:22:20.0276 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-0B-00-FF-FF
    3141;16:22:20.0276 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-0B-00-FF-FF, StartHandle: 0x000B, EndHandle: 0xFFFF
    3142;16:22:20.0276 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-0B-00-FF-FF
    3143;16:22:20.0276 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3144;16:22:20.0276 [681093730][ScriptMethodCallThread] Number of data packets sent: 3
    3145;16:22:20.0356 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3146;16:22:20.0356 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3147;16:22:20.0356 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3148;16:22:20.0556 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-12-00-0E-00-04-00-05-01-0B-00-02-29-0C-00-00-28-0D-00-03-28
    3149;16:22:20.0566 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-01-0B-00-02-29-0C-00-00-28-0D-00-03-28, Format: HandleAnd16BitUuid, Handle: 0x000B, Uuid: 0x2902, Handle: 0x000C, Uuid: 0x2800, Handle: 0x000D, Uuid: 0x2803
    3150;16:22:20.0756 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-0E-00-FF-FF
    3151;16:22:20.0756 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-0E-00-FF-FF, StartHandle: 0x000E, EndHandle: 0xFFFF
    3152;16:22:20.0756 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-0E-00-FF-FF
    3153;16:22:20.0756 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3154;16:22:20.0756 [681093730][ScriptMethodCallThread] Number of data packets sent: 4
    3155;16:22:20.0956 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3156;16:22:20.0956 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3157;16:22:20.0956 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3158;16:22:20.1156 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-18-00-14-00-04-00-05-02-0E-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-32-15-00-00
    3159;16:22:20.1156 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-02-0E-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-32-15-00-00, Format: HandleAnd128BitUuid, Handle: 0x000E, Uuid: 0x00001532-1212-EFDE-1523-785FEABCD123
    3160;16:22:20.1226 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-0F-00-FF-FF
    3161;16:22:20.1226 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-0F-00-FF-FF, StartHandle: 0x000F, EndHandle: 0xFFFF
    3162;16:22:20.1226 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-0F-00-FF-FF
    3163;16:22:20.1226 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3164;16:22:20.1236 [681093730][ScriptMethodCallThread] Number of data packets sent: 5
    3165;16:22:20.1356 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3166;16:22:20.1356 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3167;16:22:20.1356 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3168;16:22:20.1576 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0A-00-06-00-04-00-05-01-0F-00-03-28
    3169;16:22:20.1576 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-01-0F-00-03-28, Format: HandleAnd16BitUuid, Handle: 0x000F, Uuid: 0x2803
    3170;16:22:20.1696 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-10-00-FF-FF
    3171;16:22:20.1696 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-10-00-FF-FF, StartHandle: 0x0010, EndHandle: 0xFFFF
    3172;16:22:20.1696 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-10-00-FF-FF
    3173;16:22:20.1696 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3174;16:22:20.1696 [681093730][ScriptMethodCallThread] Number of data packets sent: 6
    3175;16:22:20.1756 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3176;16:22:20.1756 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3177;16:22:20.1756 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3178;16:22:20.1956 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-18-00-14-00-04-00-05-02-10-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-31-15-00-00
    3179;16:22:20.1956 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-02-10-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-31-15-00-00, Format: HandleAnd128BitUuid, Handle: 0x0010, Uuid: 0x00001531-1212-EFDE-1523-785FEABCD123
    3180;16:22:20.2086 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-11-00-FF-FF
    3181;16:22:20.2086 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-11-00-FF-FF, StartHandle: 0x0011, EndHandle: 0xFFFF
    3182;16:22:20.2096 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-11-00-FF-FF
    3183;16:22:20.2096 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3184;16:22:20.2096 [681093730][ScriptMethodCallThread] Number of data packets sent: 7
    3185;16:22:20.2156 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3186;16:22:20.2156 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3187;16:22:20.2166 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3188;16:22:20.2356 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0E-00-0A-00-04-00-05-01-11-00-02-29-12-00-03-28
    3189;16:22:20.2356 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-01-11-00-02-29-12-00-03-28, Format: HandleAnd16BitUuid, Handle: 0x0011, Uuid: 0x2902, Handle: 0x0012, Uuid: 0x2803
    3190;16:22:20.2416 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-13-00-FF-FF
    3191;16:22:20.2416 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-13-00-FF-FF, StartHandle: 0x0013, EndHandle: 0xFFFF
    3192;16:22:20.2426 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-13-00-FF-FF
    3193;16:22:20.2426 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3194;16:22:20.2426 [681093730][ScriptMethodCallThread] Number of data packets sent: 8
    3195;16:22:20.2556 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3196;16:22:20.2556 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3197;16:22:20.2556 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3198;16:22:20.2756 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-18-00-14-00-04-00-05-02-13-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-34-15-00-00
    3199;16:22:20.2756 [681093730][ReadPacketQueueThread] Received packet: AttFindInformationResponse, 05-02-13-00-23-D1-BC-EA-5F-78-23-15-DE-EF-12-12-34-15-00-00, Format: HandleAnd128BitUuid, Handle: 0x0013, Uuid: 0x00001534-1212-EFDE-1523-785FEABCD123
    3200;16:22:20.2906 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:05-00-04-00-04-14-00-FF-FF
    3201;16:22:20.2906 [681093730][ScriptMethodCallThread] Sending packet: AttFindInformationRequest, 04-14-00-FF-FF, StartHandle: 0x0014, EndHandle: 0xFFFF
    3202;16:22:20.2906 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-09-00-05-00-04-00-04-14-00-FF-FF
    3203;16:22:20.2906 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3204;16:22:20.2906 [681093730][ScriptMethodCallThread] Number of data packets sent: 9
    3205;16:22:20.2956 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3206;16:22:20.2956 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3207;16:22:20.2956 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3208;16:22:20.3156 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-09-00-05-00-04-00-01-04-14-00-0A
    3209;16:22:20.3156 [681093730][ReadPacketQueueThread] Received packet: AttErrorResponse, 01-04-14-00-0A, OpCode: FindInformationRequest, Handle: 0x0014, ErrorCode: AttributeNotFound
    3210;16:22:20.3356 [681093730][ScriptMethodCallThread] Discovering all attribute UUIDs
    3211;16:22:20.3366 [681093730][ScriptMethodCallThread] Handle: 0x0001, UUID: 0x2800
    3212;16:22:20.3436 [681093730][ScriptMethodCallThread] Received a Service group UUID
    3213;16:22:20.3436 [681093730][ScriptMethodCallThread] Handle: 0x0002, UUID: 0x2803
    3214;16:22:20.3476 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3215;16:22:20.3476 [681093730][ScriptMethodCallThread] Handle: 0x0003, UUID: 0x2A00
    3216;16:22:20.3526 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3217;16:22:20.3536 [681093730][ScriptMethodCallThread] Handle: 0x0004, UUID: 0x2803
    3218;16:22:20.3536 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3219;16:22:20.3546 [681093730][ScriptMethodCallThread] Handle: 0x0005, UUID: 0x2A01
    3220;16:22:20.3586 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3221;16:22:20.3586 [681093730][ScriptMethodCallThread] Handle: 0x0006, UUID: 0x2803
    3222;16:22:20.3586 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3223;16:22:20.3586 [681093730][ScriptMethodCallThread] Handle: 0x0007, UUID: 0x2A04
    3224;16:22:20.3626 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3225;16:22:20.3636 [681093730][ScriptMethodCallThread] Handle: 0x0008, UUID: 0x2800
    3226;16:22:20.3636 [681093730][ScriptMethodCallThread] Received a Service group UUID
    3227;16:22:20.3636 [681093730][ScriptMethodCallThread] Handle: 0x0009, UUID: 0x2803
    3228;16:22:20.3646 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3229;16:22:20.3646 [681093730][ScriptMethodCallThread] Handle: 0x000A, UUID: 0x2A05
    3230;16:22:20.3706 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3231;16:22:20.3706 [681093730][ScriptMethodCallThread] Handle: 0x000B, UUID: 0x2902
    3232;16:22:20.3776 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3233;16:22:20.3776 [681093730][ScriptMethodCallThread] Handle: 0x000C, UUID: 0x2800
    3234;16:22:20.3776 [681093730][ScriptMethodCallThread] Received a Service group UUID
    3235;16:22:20.3776 [681093730][ScriptMethodCallThread] Handle: 0x000D, UUID: 0x2803
    3236;16:22:20.3776 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3237;16:22:20.3786 [681093730][ScriptMethodCallThread] Handle: 0x000E, UUID: 0x15321212EFDE1523785FEABCD123
    3238;16:22:20.3816 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3239;16:22:20.3816 [681093730][ScriptMethodCallThread] Handle: 0x000F, UUID: 0x2803
    3240;16:22:20.3816 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3241;16:22:20.3816 [681093730][ScriptMethodCallThread] Handle: 0x0010, UUID: 0x15311212EFDE1523785FEABCD123
    3242;16:22:20.3816 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3243;16:22:20.3826 [681093730][ScriptMethodCallThread] Handle: 0x0011, UUID: 0x2902
    3244;16:22:20.3826 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3245;16:22:20.3826 [681093730][ScriptMethodCallThread] Handle: 0x0012, UUID: 0x2803
    3246;16:22:20.3826 [681093730][ScriptMethodCallThread] Received a Characteristic Group group UUID
    3247;16:22:20.3826 [681093730][ScriptMethodCallThread] Handle: 0x0013, UUID: 0x15341212EFDE1523785FEABCD123
    3248;16:22:20.3826 [681093730][ScriptMethodCallThread] Received a Characteristic Group group attribute
    3249;16:22:20.3836 [681093730][ScriptMethodCallThread] Discovering all attribute values
    3250;16:22:20.3966 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-01-00
    3251;16:22:20.3966 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-01-00, Handle: 0x0001
    3252;16:22:20.3966 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-01-00
    3253;16:22:20.3966 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3254;16:22:20.3966 [681093730][ScriptMethodCallThread] Number of data packets sent: 10
    3255;16:22:20.4156 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3256;16:22:20.4156 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3257;16:22:20.4156 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3258;16:22:20.4356 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-07-00-03-00-04-00-0B-00-18
    3259;16:22:20.4356 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-00-18, AttributeValue: 00-18
    3260;16:22:20.4496 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0001, value (0x): 00-18
    3261;16:22:20.4536 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-02-00
    3262;16:22:20.4536 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-02-00, Handle: 0x0002
    3263;16:22:20.4536 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-02-00
    3264;16:22:20.4536 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3265;16:22:20.4536 [681093730][ScriptMethodCallThread] Number of data packets sent: 11
    3266;16:22:20.4756 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3267;16:22:20.4756 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3268;16:22:20.4756 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3269;16:22:20.4956 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0A-00-06-00-04-00-0B-0A-03-00-00-2A
    3270;16:22:20.4956 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-0A-03-00-00-2A, AttributeValue: 0A-03-00-00-2A
    3271;16:22:20.4996 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0002, value (0x): 0A-03-00-00-2A
    3272;16:22:20.5026 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-03-00
    3273;16:22:20.5026 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-03-00, Handle: 0x0003
    3274;16:22:20.5026 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-03-00
    3275;16:22:20.5026 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3276;16:22:20.5026 [681093730][ScriptMethodCallThread] Number of data packets sent: 12
    3277;16:22:20.5156 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3278;16:22:20.5156 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3279;16:22:20.5156 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3280;16:22:20.5356 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0C-00-08-00-04-00-0B-50-32-4D-5F-44-46-55
    3281;16:22:20.5356 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-50-32-4D-5F-44-46-55, AttributeValue: 50-32-4D-5F-44-46-55
    3282;16:22:20.5486 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0003, value (0x): 50-32-4D-5F-44-46-55
    3283;16:22:20.5536 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-04-00
    3284;16:22:20.5536 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-04-00, Handle: 0x0004
    3285;16:22:20.5546 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-04-00
    3286;16:22:20.5546 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3287;16:22:20.5546 [681093730][ScriptMethodCallThread] Number of data packets sent: 13
    3288;16:22:20.5756 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3289;16:22:20.5756 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3290;16:22:20.5766 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3291;16:22:20.5956 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0A-00-06-00-04-00-0B-02-05-00-01-2A
    3292;16:22:20.5956 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-02-05-00-01-2A, AttributeValue: 02-05-00-01-2A
    3293;16:22:20.6006 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0004, value (0x): 02-05-00-01-2A
    3294;16:22:20.6016 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-05-00
    3295;16:22:20.6016 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-05-00, Handle: 0x0005
    3296;16:22:20.6016 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-05-00
    3297;16:22:20.6016 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3298;16:22:20.6016 [681093730][ScriptMethodCallThread] Number of data packets sent: 14
    3299;16:22:20.6156 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3300;16:22:20.6156 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3301;16:22:20.6156 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3302;16:22:20.6356 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-07-00-03-00-04-00-0B-00-00
    3303;16:22:20.6356 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-00-00, AttributeValue: 00-00
    3304;16:22:20.6476 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0005, value (0x): 00-00
    3305;16:22:20.6496 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-06-00
    3306;16:22:20.6506 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-06-00, Handle: 0x0006
    3307;16:22:20.6506 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-06-00
    3308;16:22:20.6506 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3309;16:22:20.6506 [681093730][ScriptMethodCallThread] Number of data packets sent: 15
    3310;16:22:20.6556 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3311;16:22:20.6556 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3312;16:22:20.6556 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3313;16:22:20.6776 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0A-00-06-00-04-00-0B-02-07-00-04-2A
    3314;16:22:20.6776 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-02-07-00-04-2A, AttributeValue: 02-07-00-04-2A
    3315;16:22:20.6886 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0006, value (0x): 02-07-00-04-2A
    3316;16:22:20.6896 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-07-00
    3317;16:22:20.6896 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-07-00, Handle: 0x0007
    3318;16:22:20.6896 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-07-00
    3319;16:22:20.6896 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3320;16:22:20.6896 [681093730][ScriptMethodCallThread] Number of data packets sent: 16
    3321;16:22:20.6956 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3322;16:22:20.6956 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3323;16:22:20.6956 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3324;16:22:20.7156 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0D-00-09-00-04-00-0B-0C-00-18-00-00-00-90-01
    3325;16:22:20.7156 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-0C-00-18-00-00-00-90-01, AttributeValue: 0C-00-18-00-00-00-90-01
    3326;16:22:20.7276 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0007, value (0x): 0C-00-18-00-00-00-90-01
    3327;16:22:20.7316 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-08-00
    3328;16:22:20.7316 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-08-00, Handle: 0x0008
    3329;16:22:20.7316 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-08-00
    3330;16:22:20.7316 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3331;16:22:20.7326 [681093730][ScriptMethodCallThread] Number of data packets sent: 17
    3332;16:22:20.7396 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3333;16:22:20.7407 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3334;16:22:20.7407 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3335;16:22:20.7557 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-07-00-03-00-04-00-0B-01-18
    3336;16:22:20.7557 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-01-18, AttributeValue: 01-18
    3337;16:22:20.7637 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0008, value (0x): 01-18
    3338;16:22:20.7647 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-09-00
    3339;16:22:20.7647 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-09-00, Handle: 0x0009
    3340;16:22:20.7647 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-09-00
    3341;16:22:20.7647 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3342;16:22:20.7647 [681093730][ScriptMethodCallThread] Number of data packets sent: 18
    3343;16:22:20.7757 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3344;16:22:20.7757 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3345;16:22:20.7757 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3346;16:22:20.7957 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-0A-00-06-00-04-00-0B-20-0A-00-05-2A
    3347;16:22:20.7957 [681093730][ReadPacketQueueThread] Received packet: AttReadResponse, 0B-20-0A-00-05-2A, AttributeValue: 20-0A-00-05-2A
    3348;16:22:20.8117 [681093730][ScriptMethodCallThread] Received Read Response, handle: 0x0009, value (0x): 20-0A-00-05-2A
    3349;16:22:20.8127 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-0A-00
    3350;16:22:20.8127 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-0A-00, Handle: 0x000A
    3351;16:22:20.8127 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-0A-00
    3352;16:22:20.8127 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3353;16:22:20.8127 [681093730][ScriptMethodCallThread] Number of data packets sent: 19
    3354;16:22:20.8157 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3355;16:22:20.8157 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3356;16:22:20.8157 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3357;16:22:20.8357 [681093730][ReadPacketQueueThread] Serial port read: 02-00-20-09-00-05-00-04-00-01-0A-0A-00-02
    3358;16:22:20.8357 [681093730][ReadPacketQueueThread] Received packet: AttErrorResponse, 01-0A-0A-00-02, OpCode: ReadRequest, Handle: 0x000A, ErrorCode: ReadNotPermitted
    3359;16:22:20.8607 [681093730][ScriptMethodCallThread] Received Error Response: READ_NOT_PERMITTED, handle: 0x000A
    3360;16:22:20.8627 [681093730][ScriptMethodCallThread] WRITE DATA PACKET:03-00-04-00-0A-0B-00
    3361;16:22:20.8627 [681093730][ScriptMethodCallThread] Sending packet: AttReadRequest, 0A-0B-00, Handle: 0x000B
    3362;16:22:20.8627 [681093730][ScriptMethodCallThread] Serial port write: 02-00-00-07-00-03-00-04-00-0A-0B-00
    3363;16:22:20.8627 [681093730][ScriptMethodCallThread] Data buffer queue length (+1): 1
    3364;16:22:20.8627 [681093730][ScriptMethodCallThread] Number of data packets sent: 20
    3365;16:22:20.8757 [681093730][ReadPacketQueueThread] Serial port read: 04-13-05-01-00-00-01-00
    3366;16:22:20.8757 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_NUMBER_OF_COMPLETED_PACKETS, NumberOfHandles: 1, ConnectionHandle: 0x0000, NumberOfPackets: 1
    3367;16:22:20.8757 [681093730][ReadPacketQueueThread] Data buffer queue length: 0
    3368;16:22:23.8958 [681093730][ReadPacketQueueThread] Serial port read: 04-05-04-00-00-00-08
    3369;16:22:23.8958 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_DISCONNECTION_COMPLETE ConnectionHandle: 0x0000, Reason: BTLE_CONNECTION_TIMEOUT
    3370;16:22:23.9088 [681093730][ReadPacketQueueThread] Received LL Connection Termination Event, reason 08
    3371;16:22:23.9118 [681093730][ScriptThread] Lost connection to device. Reason: BTLE_CONNECTION_TIMEOUT
    3372;16:22:23.9308 [681093730][] SERVER: Received packet <HciEvent: eventCode=0x0A> - <HciEvent: eventCode=0x0A>
    3373;16:22:23.9308 [681093730][] SERVER: Received Link Loss
    3374;16:22:23.9408 [681093730][ScriptMethodCallThread] Wait canceled: no connection.
    3375;16:22:23.9418 [681093730][ScriptMethodCallThread] No response received for ReadRequest on handle 0x000B. Disconnecting..
    3376;16:22:23.9458 [681093730][ScriptMethodCallThread] HCI command: BTLE_CMD_DISCONNECT, ConnectionHandle: 0x0000, Reason: BTLE_REMOTE_USER_TERMINATED_CONNECTION
    3377;16:22:23.9468 [681093730][ScriptMethodCallThread] Serial port write: 01-06-04-03-00-00-13
    3378;16:22:23.9478 [681093730][ScriptMethodCallThread] Service discovery aborted, connection terminated.
    3379;16:22:23.9498 [681093730][ReadPacketQueueThread] Serial port read: 04-0F-04-02-01-06-04
    3380;16:22:23.9498 [681093730][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_STATUS, OpCode: BTLE_CMD_DISCONNECT, Status: BTLE_STATUS_CODE_UNKNOWN_CONNECTION_IDENTIFIER
    3381;16:22:23.9708 [681093730][ScriptMethodCallThread] ('C:\\Program Files (x86)\\Nordic Semiconductor\\Master Control Panel\\3.10.0.14\\lib\\script.py', 866, 'discoverServices', 'requestAllAttributeData(handleDict)')
    	('C:\\Program Files (x86)\\Nordic Semiconductor\\Master Control Panel\\3.10.0.14\\lib\\script.py', 954, 'requestAllAttributeData', '_readAttributeValue(handle)')
    	('C:\\Program Files (x86)\\Nordic Semiconductor\\Master Control Panel\\3.10.0.14\\lib\\script.py', 1407, '_readAttributeValue', 'raise Exception("Service discovery aborted, connection terminated.")')
