NRF51822 + custom board not quite working
Hi! My problem is that my code works on the devkit PCA10004(PCB antenna) but not on my own custom board. The devboard can be connected to and all characteristics can be read correctly. With my custom board I can program it, debug it, advertise but I can not connect to the nrf51822. In master control panel i can see the nrf51822, i get -44 to -70db depending on the proximity so the antenna(Tried 2450AT18A100E and a 31mm wire, both works about the same) + balun(2450BM14A0002T) seems to work. I get the address, name and so on but when i click service discovery I get
[11:21:57.3] Device discovery stopped
[11:21:58.4] GetDeviceInfo()
[11:21:58.7] ----------------------------
[11:21:58.7] Connected to device
[11:21:58.7] Role: 0
[11:21:58.7] PeerAddressType: 1
[11:21:58.7] PeerAddress (MSB): D86D1B8280D6
[11:21:58.7] Connection Interval: 20.0ms
[11:21:58.7] Connection Latency: 0
[11:21:58.7] Supervision Timeout: 3000ms
[11:21:58.7] Clock Accuracy: (1)
[11:21:58.7] Connected to address: D86D1B8280D6
[11:21:58.7] Starting a Read Information Request on the whole remote DB
[11:21:58.8] Lost connection to device. Reason: BTLE_CONN_FAILED_TO_BE_ESTABLISHED
[11:21:58.8] SERVER: Received packet <HciEvent: eventCode=0x0A> - <HciEvent: eventCode=0x0A>
[11:21:58.8] SERVER: Received Link Loss
[11:22:03.7] Discovering all attribute UUIDs
[11:22:03.7] Lost connection before service discovery was complete
I measure the VDD_PA with my scope and the RF frontend gets biased for 400µs in three bursts. But the burst looks exactly the same when i click service discovery. On the devboard they are not the same. The code does not crash, the board continues to advertise and can be when i click start discovery again. The code never reaches the app_error_handler function so no function gives any error(this function contains a while(1);. The code never reaches the ble_evt_dispatch function so no connection event nor disconnection event are generated.
So my conclution is that my custom boards can not recieve anything but only transmit.
The primary crystal starts when the nrf51822 sends data and the low power crystam(32kHz) runns always.
I have attached the PCB, it is 2 layers, 1.6mm. The top plane is basicly a solid groundplane, a few other wires runns there but not close to the RF part.
The code is a modified version of the HRS example.
I have exaclty the same code running on both the devboard and the custom board and the softdevice is loaded.
Do you guys have any clue why I can not receive anything with my custom board?
The only difference I can think of to the devboard is the balun, but i can transmitt, does not that mean that i should be able to receive?
Thanks //Victor @ pluspole.
PCB.PDF
