Adding Multiple Presentation Format Descriptors
The Bluetooth specification states:
If more than one Characteristic Presentation Format declarations exist, in a characteristic definition, then a Characteristic Aggregate Format declaration shall exist as part of the characteristic definition
However, there doesn't seem to be any way to add the Presentation Format descriptor except using sd_ble_gatts_characteristic_add(), which only seems to allow a single PF descriptor to be specified.
Calling sd_ble_gatts_descriptor_add() to attempt to manually add PF descriptors fails with the error code NRF_ERROR_FORBIDDEN.
Is there any way to add multiple Characteristic Presentation Format descriptors to a single characteristic?
edit: This is for a characteristic value that is comprised of 4 discrete quantities:
byte  | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 |
value |  1st  |      2nd      |      3rd      |        4th        |
The 1st value is 16-bit signed integer, the 2nd-4th values are 32-bit signed integers.
  • I have the same issue, with multiple quantities in a single characteristic, which shouldn't be split up because they are closely related and normally need to be written together. In one case I have two float32 values followed by a uint8. I'd like to have the CPF descriptors and CAF descriptor so that peers that aren't hard-coded can parse it properly.
    It would be especially nice if nRFConnect would recognize that and deal with it appropriately, but I'm not really expecting that.
