Protect NVM from being overwritten during reflash
I'm using the pstorage driver on the nRF51 to maintain several NVM variables. The NVM functions correctly and maintains state between power cycles. However, when I reflash the device using OTA reflash (application only, not SoftDevice), all of my NVM variables are reset to 0xFF. How do I prevent reflashing from modifying my NVM variables?
This is the command line I'm using to generate the zip file used for OTA reflash -
nrfutil dfu genpkg myProgram.zip --application myProgram.hex --application-version 0xffff --dev-revision 0xffff --dev-type 0xffff --sd-req 0xfffe
Thanks
Brian
  • Thank you for the links above. I'm calling device_manager_init() before calling pstorage_register, so I've set DFU_APP_DATA_RESERVED to CODE_PAGE_SIZE * 3. I've also looked at the map files for both my bootloader and app. I should have plenty of free space to update both of these together. My bootloader starts at 0x3b800, and my app goes from 0x18000 to 0x24A28, which has a length of 0xca28. With DFU_APP_DATA_RESERVED set to CODE_PAGE_SIZE * 3, I believe that the App Data section then goes from 0x3ac00 to 0x3b800. This leaves a Free Space section from 0x24a28 to 0x3ac00, which is 0x161d5 in length. I've now tried to update my bootloader only over-the-air using the following command to generate the .zip file: nrfutil dfu genpkg my_bootloader.zip --bootloader my_bootloader.hex --dev-revision 0xffff --dev-type 0xffff --sd-req 0xfffe I copy the resulting file to my Android phone, and using nRF Toolbox, I reflash the bootloader. The reflash process indicates it is successful, however, my device will no longer boot up! The only change I've made is adding: #define DFU_APP_DATA_RESERVED CODE_PAGE_SIZE * 3 to dfu_types.h. I see in the last link above a reference to a similar problem. The suggested solution is to modify dfu_bl_image_validate() because the DFU_BANK_1_REGION_START has changed from the old bootloader to the new bootloader. Could you explain further what that modification should be? Thanks.
  • FormerMember
    0 FormerMember
    dfu_bl_image_validate() does only check the old DFU_BANK_1_REGION_START, in addition, you need to add a check for the new DFU_BANK_1_REGION_START.
