I am trying to implement a Single Bank DFU over Bluetooth for my nRF51822 (256KB / 16KB RAM) using SDK v7.1 and Softdevice 110. I am using GCC to compile the bootloader and in order to switch from dual bank (which I was doing previously before my application size did not allow it anymore) to single bank mode, I changed from dfu_dual_bank.c to dfu_single_bank.c in the Makefile. The complied bootloader works fine as I can upload new firmware onto the chip using FOTA. But, if however the process is interrupted, the chip bricks and has to be flashed again.
I figured out that upon load, the bootloader checks if the app present in the chip is valid by comparing its crc16 checksum with the checksum saved in the bootloader settings. I believe that here lies my problem because if this check failed after an unsuccessful FOTA attempt, the chip should remain in DFU mode but that is not the case. Can anybody shed some light into where the problem may lie?
Any response is much appreciated.
-ashakya
