Hi All, I want to connect NRF51822 with touch sensor. it's possible or not? how to get GPIO example for NRF51822?
i try to upload nrf51822_beacon_app example. it's given in Firmware 1.1.0. in that i m try to change the color of LED. because by default in NRF51822 beacon code is there.in that if pressing sw2 then it will blink yellow light. i modify that example and wrote red instead of yellow light. after compile and generate a hex file. upload using NRF51dk kit through NrfGo studio. it will show Programmed Successfully. but it not effect on NRF51822 Beacon. so where i stuck? give me solution.
Could you post some code snippets of what you have changed, and a link to the exact example firmware you are using? You should also try debugging, to see if your application is failing.
FIRMWARE V1.1.1 i m using this firmware (ABOVE link) in that nRF51822 Beacon v1.1.1/sourcecode/Nrf51_beacon/ble_app_beacon/pca20006/s110/arm/ble_app_beacon_s110_pca20006 open a Ble_app_beacon example in Keil5 and modify in main.c
"#define APP_CONFIG_MODE_LED_MSK (LED_R_MSK | LED_G_MSK)"
instead of that (LED_R_MSK | LED_G_MSK) i put only (LED_R_MSK)
after that compilation is successfully done n generate a hex file n upload that hex file in NRF51822 Beacon. it shows application programmed successfully. but it's not effect on NRF51822 Beacon.
ANS for above comment. thanks nordic
