Hi
I'm fighting to read characteristics of my service with sd_ble_gattc_char_value_by_uuid_read. I'm using SD130 V2.0.1 and SDK11.
Here are some snippets from my central device. I register my custom 128bit UUID in the SD130 like so:
err_code = sd_ble_uuid_vs_add(&m_svc_uuid, &m_uuid_type);
m_uuid.type = m_uuid_type;
m_uuid.uuid = MH_BLE_UUID_SERVICE;
then the normal scan and connect takes place. In the ble connect handler I call:
m_range.start_handle = 0x0001; // CHAR Start on create: 0x1101
m_range.end_handle = 0xffff; // CHAR END on create: 0x1105
err_code = sd_ble_gattc_char_value_by_uuid_read(p_gap_evt->conn_handle, &m_uuid_type, &m_range);
No matter if I add the known characteristic handles or the full range, the error is the same. The function call executes with NRF_SUCCESS, but in the BLE_GATTC_EVT_CHAR_VAL_BY_UUID_READ_RSP event handler, the returned status is always BLE_GATT_STATUS_ATTERR_ATTRIBUTE_NOT_FOUND 0x010A.
Am I missing something or is my call in the wrong place? It would be great if somebody could supply a more detailed explanation then the one in the docs. I couldn't find any example using the call on devzone or in SDK exmples....
Thanks
