Problem using GPIO- and BSP-module simultaneously
last week I was trying to integrate a wake-on-motion-functionality for my hardware using some interrupt-handling. While that problem is solved, I came across some kind of interdependency between initializing the GPIO- and the BSP-module simultaneaously.
Here is the code of the 2 functions which I am using:
a) gpio_config()
    ret_code_t err_code;
    check_error_code(__func__, err_code, 1);
    nrf_drv_gpiote_in_config_t pin_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    err_code = nrf_drv_gpiote_in_init(MOTION_IRQ_PIN, &pin_config, motion_irq_evt_handler);
    check_error_code(__func__, err_code, 2);
    nrf_drv_gpiote_in_event_enable(MOTION_IRQ_PIN, true);
    printf("%s(): GPIOs initialized\r\n", __func__);
b) bsp_config(bool *p_erase_bonds)
    bsp_event_t startup_event;
    uint32_t err_code = NRF_SUCCESS;
    err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                        APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
						bsp_evt_handler);
	}// if (err_code != NRF_ERROR_INVALID_STATE)
    printf("%s(): BSP initialized\r\n", __func__);
c) Calling-procedure in main()
    bool erase_bonds = true;
    system_startup();
    // Initialize hmi
    gpio_config();
    bsp_config(&erase_bonds);
    // Initialize peer-manager
    pm_config(erase_bonds);
    // Initialize bt-support
    ble_stack_init();
    gap_params_init();
    services_init();
When I first started using this particular procedure with SDK v12.0.0, I was experiencing the a problem with error-code NRF_ERROR_INVALID_STATE (0x0008) inside bsp_config(). So I decided to just uncomment the functionality within bsp_config(), but then I was running into some dependency-issues regarding the ble-advertising. Then I went for a simple workaround by just excluding this error-code from being handled by APP_ERROR_CHECK(), which basically just "disguises" the error and doesnt actually solve it.
After upgrading my SDK to v12.2.0 - without adjusting anything of the code-parts a)-c) - the entire functionality within bsp_config() seems to be causing a problem, so that I actually have to uncomment all of its occurences to keep my system operational.
Now to my questions:
a) Is there any specific order in what way the initialization of the GPIO- and the BSP-module should be handled?
b) Does the upgrade from SDK v12.0.0 to v12.2.0 require any adjustment of the bsp_config()-code or the initialization-order inside main()?
I was already cross-checking with some of the SDK-examples, but the code inside bsp_config() is pretty much the same everywhere and also the call inside main(), which always happens before initializing the peer-manager or the ble-stack!
This is where I am lost...
  • I will do that asap, but I cant do it during the next week, since I am on a business-trip! I will get back to you - thank you very much for your efforts so far!
  • Now I did run the test with disabling bsp_btn_ble_init(), but there was no change in the behaviour!
  • Problem finally solved... :)
    This issue was caused by a missing adaption for handling the bsp-module in SDK v12.2.0, that required a change in the Makefile and the project-structure within Eclipse.
    Previously in SDK v12.0.0 the bsp-sources where available through the examples/bsp-folder, while in SDK v12.2.0 they got moved to components/libraries/bsp. Since the SDK-structure for v12.2.0 didnt got setup properly with deleting all previous content of SDK v12.0.0, it caused an indexing-error in Eclipse so that the bsp-module-source still got referenced to the examples/bsp-location.
    Somehow that also created a problem with handling the BOARD_PCA10040-flag properly, which basically made the functions in bsp_config() doing nothing at all. In addition to that the Makefile obviously needed certain changes in the SRC_FILES- and INC_FOLDERS-section (also including boards.c as new file).
    Thanks again for your help!
