Timer interrupt don't work in ble_app_uart of SDK6.1.0
Hello everybody
I am working with the Raytac BLE Module "MDBT40", which is based on nrf51822.
And I am testing example project "ble_app_uart" in the SDK6.1.0 now.
But there are some problems when I add a new timer.
In the project "ble_app_uart", It contain only RTC timer.
However, I can't understand how the RTC interrupt work in the demo code.
So I add a timer2 in the project as below.
I hope it turn on LED once 100ms.
void start_timer2(void)
  // Start 16 MHz crystal oscillator.
  NRF_CLOCK->TASKS_HFCLKSTART    = 1;
  while(NRF_CLOCK->EVENTS_HFCLKSTARTED==0){}
  NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;  // Set the timer in Counter Mode
  NRF_TIMER2->TASKS_CLEAR = 1;               // clear the task first to be usable for later
  NRF_TIMER2->PRESCALER = 9;                             //Set prescaler. Higher number gives slower timer. Prescaler = 0 gives 16MHz timer. Prescaler = 9 gives 31250 Hz timer, 1tick 32us.
  NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;		 //Set counter to 16 bit resolution
  NRF_TIMER2->CC[0] = 3125;                              //Set value for TIMER2 compare register 0. Period is 32us * 3125 = 100ms.
  // Enable interrupt on Timer 2, for CC[0]
  NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos);
  NVIC_EnableIRQ(TIMER2_IRQn);
  NRF_TIMER2->TASKS_START = 1;               // Start TIMER2
/** TIMTER1 peripheral interrupt handler. This interrupt handler is called whenever there it a TIMER1 interrupt
void TIMER2_IRQHandler(void)
	if ((NRF_TIMER2->EVENTS_COMPARE[0] != 0) && ((NRF_TIMER2->INTENSET & TIMER_INTENSET_COMPARE0_Msk) != 0))
		NRF_TIMER2->EVENTS_COMPARE[0] = 0;           //Clear compare register 0 event
		NRF_TIMER2->TASKS_CLEAR=1;
		// turn on LED
		nrf_gpio_pin_set(D03);
		while(1){};
And I put "start_timer2();" after "timers_init();" in main function.
But it doesn't interrupt while running.
What I miss in the process?
Sorry for my poor English.
And thanks in advance!
More test information
this is my main function
	static uint8_t index = 0;
	uint8_t index_backup = 0;
	uint8_t newbyte;
		int i=0;
	// Initialize
	gpio_init();
	timers_init();
	start_timer2();
	uart_init();
	ble_stack_init();
	gap_params_init();
	services_init();
	advertising_init();
	conn_params_init();
	sec_params_init();
	uart_putstring((const uint8_t *)START_STRING);
	advertising_start();
	// Enter main loop
	for (;;)
		/*Stop reading new data if there are no ble buffers available */
		if(ble_buffer_available)
			if(app_uart_get(&newbyte) == NRF_SUCCESS)
				data_array[index] = newbyte;
				if (data_array[index] == '\n')
					ble_buffer_available = ble_attempt_to_send(&data_array[0],index);
					index_backup = index;
					  if(ble_buffer_available) index = 0;
				else if (index == (BLE_NUS_MAX_DATA_LEN-1))
					ble_buffer_available = ble_attempt_to_send(&data_array[0],index+1);
					index_backup = index+1;
							index++;
		/* Re-transmission if ble_buffer_available was set to false*/
		if(tx_complete)
			tx_complete=false;
			index = index_backup;
		power_manage();
For testing, I turn on LED to make sure when process get trouble.
And process stop between turnonLED1 and turnonLED2 which in ble_stack_init();
	uint32_t err_code;
	nrf_gpio_cfg_input(EXT_XTAL_MODE,NRF_GPIO_PIN_PULLUP);
	TurnonLED1();
	  if(nrf_gpio_pin_read(EXT_XTAL_MODE) == 1)
		  // Initialize SoftDevice.
		SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_1000MS_CALIBRATION, false);
		SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
	TurnonLED2();
	// Enable BLE stack
	ble_enable_params_t ble_enable_params;
	memset(&ble_enable_params, 0, sizeof(ble_enable_params));
	ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
	err_code = sd_ble_enable(&ble_enable_params);
	// Subscribe for BLE events.
	err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
Then I change position of start_time2(); in main(); as below
	uint8_t newbyte;
		int i=0;
	// Initialize
	//leds_init();
		gpio_init();
	timers_init();
		nrf_gpio_pin_clear(DIG3);
	//buttons_init();
	uart_init();
	ble_stack_init();
	gap_params_init();
	services_init();
	advertising_init();
	conn_params_init();
	sec_params_init();
		start_timer2();
	//skip...
Process stop between turnonLED3 and turnonLED4 which in start_timer2();
	turnonLED3();
	turnonLED4();
  // Enable interrupt on Timer 2, both for CC[0] and CC[1] compare match events
Maybe it helpful to find problem?
Just more testing
I use app_timer instead of timer2.
It's working but "TIMER_INTERVAL" didn't perform as expected.(It take longer than 1ms to trigger interrupt.)
Are there higher priority interrupt cause it?(Bluetooth or Uart?)
And why timer2 can't work fine?
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS            2                                           /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
static app_timer_id_t  m_app_timer_id;
#define TIMER_INTERVAL  APP_TIMER_TICKS(1, APP_TIMER_PRESCALER) // Timer_interval is 1ms
static void start_timer(void)
	uint32_t err_code;
	err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
void display_timeout_handler(void * p_context)
		DriveXDig7Segment();
	uint8_t newbyte;
	// Initialize
	//leds_init();
		gpio_init();
	timers_init();
	//buttons_init();
	uart_init();
	ble_stack_init();
	gap_params_init();
	services_init();
	advertising_init();
	conn_params_init();
	sec_params_init();
		start_timer();
	skip...
  • Hi Petter.
    I debug with RTT viewer by "SEGGER_RTT_WriteString" and "SEGGER_RTT_printf".
    When "start_timer2();" is before "ble_stack_init();", process reset repeatedly and return to beginning of main.
    "ble_stack_init();" seem contain something about "softdevice_handler_init", lfclk init, ...
    I don't know how it work and take how it affect timer2(Maybe it affect hfclk actually).
  • Here is code.
    	uint32_t err_code;
    	// Enable BLE stack
  • int main(void) {
        uint8_t newbyte;
    	uint32_t isrunning = 0;
    	g_CounterDriveSegment = 0;
    	#ifdef NRF_RTT_SHOW
    	SEGGER_RTT_WriteString(0, "Main Start!\n");
        // Initialize
    	gpio_init();
        timers_init();
    	uart_init();
        ble_stack_init();
    start_timer2();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
        sec_params_init();
    	#ifdef NRF_RTT_SHOW
    	SEGGER_RTT_WriteString(0, "Loop Start!\n");
        // Enter main loop
        for (;;)
        { SKIP...}
  • Where does it reset? Do you get to ble_stack_init()? Have you seen this?
  • Hi Petter
    I put some printf in "SOFTDEVICE_HANDLER_INIT".
    But it didn't finish "softdevice_handler_init".
    So I didn't get ERROR_CODE value.
