Can the central device (ble_app_hrs_c for example) scan for and connect to a custom peripheral device (not nRF based)?
The FW on a peripheral device doesn't have to be the heart rate example, any other peripheral example will do the same thing.
Yes, I've added NRF_LOG_xxx inside of the case BLE_GAP_EVT_ADV_REPORT:, at the beginning of the on_ble_evt() function and inside of the ble_evt_dispatch() function. I see this logs only when the nRF peripheral device is turned on (with any of the peripheral examples), so I assume it has to be something with the SoftDevice?
Re-flashing the central FW didn't help.
@mtudan btw.I cannot compile ble_central\ble_app_hrs_c from nRF5 SDK v13.0.0 because code size exceeds limit in Keil for free/evaluation license but I took ble_central\ble_app_uart_c project and by adding following code to line #422 of main.c (right after case BLE_GAP_EVT_ADV_REPORT: { ) I can now observe load of adv. reports captured in the console.
printf("on_ble_evt(BLE_GAP_EVT_ADV_REPORT):\r\n");
if (p_gap_evt->params.adv_report.dlen > 0) {
printf("[0x%02X", p_gap_evt->params.adv_report.data[0]);
for(uint32_t index = 1; index < p_gap_evt->params.adv_report.dlen; index++) {
printf(":0x%02X", p_gap_evt->params.adv_report.data[index]);
printf("]\r\n");
@endnode thanks for the info. I found it really easy to scan for a custom peripheral device with the ble_app_hrs_c example. Just disable the whitelist and enable active scanning mode in the scan_start() function:
m_scan_param.active = 1;
m_scan_param.use_whitelist = 0;
m_whitelist_disabled = true;
