Bricked Sparkfun nRF52832?
I have the nRF52DK board and I am using that to reprogram the Sparkfun breakout. However, initially, I was using the Sparkfun Beefy UART device to flash the nRF52832 to begin my SPI project using BLE.
What happened: Firstly, I did something dumb.
Not getting the SPI example to work on the breakout board, I started diminishing the example's main loop to toggle an LED. This, of course, was being done at 3:30AM and I connected the LED to pin 8 and then the board can not be flashed.
In fact, the board does not acknowledge the initial transmission from the nrfutil.py utility.
Onto the nRF52 DK:
I can read the memory on the affected breakout board using the pin 19 interface of the evaluation board. I can erase the memory and write new memory. I even went so far to purchase another breakout board, savebin 512KB of working flash memeory and loadbin this file onto the affected board:
Nothing.
Failed to upgrade target. Error is: No data received on serial port. Not able to proceed.
Possible causes:
  • bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
  • baud rate or flow control is not the same as in the target bootloader.
  • target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
Question:
Is there a low level checksum I can obtain that would indicate whether the board has a hardware failure?
Is the board truly bricked or can it be jump started somehow - like setting a PC register?
Is there a known flash bin file that will do some HelloWorld dance?
Destination green recycle?
Thanks
  • Thanks for the input. The insistence on the UART is the setup I had just settled on. I use MacOS and I was able to get a script to compile any SDK example and flash it to the device using the nrfutil program. I am new to this type of activity, so I was elated that things were going so well.
    What is fantastic about this experience is I have a much deeper understanding than what the UART method would have brought. This is important as when I move onto my own circuit board using the nRF52832, I will need to program it somehow and this is where I shall be blessed to have had this experience.
    I anticipate I shall come to understand the system better to be able to explain with certainty why the board is exhibiting the behaviour it is.
    Until then, thank you.
  • The device suffered from some trauma that caused Pin27, the pin used for RX for a UART DFU, to remain high or 3.3V. I was able to use a modified Blinky program to toggle an LED on this pin to witness that the LED always remained lit. On a "good" device, the LED flashed properly.
    Thus, although I can flash the device with the NRF52_DK using nrfjprog, anything dependent on P26 such as the nrfutil program using UART the device is impaired.
