How to read manufacturer specific data
Hi, i'm working a BLE gateway with NRF52DK and S132 by using the demo example central uart.
The peripheral equipement advertise manufacturer data like this: 0x0001 during 5sec then 0x0002 during 5 sec and stop advertise.
But I want my gateway can only connect if the device advertise 0x0002 and not 0x0001.
So my question is how to get the manufacturer specific data in ble_app_uart_c ?
Thanks you for your answers !
  • The filter feature only supports the following types:
    /**@brief Types of filters.
    typedef enum
        SCAN_NAME_FILTER,       /**< Filter for names. */
        SCAN_SHORT_NAME_FILTER, /**< Filter for short names. */
        SCAN_ADDR_FILTER,       /**< Filter for addresses. */
        SCAN_UUID_FILTER,       /**< Filter for UUIDs. */
        SCAN_APPEARANCE_FILTER, /**< Filter for appearances. */
    } nrf_ble_scan_filter_type_t;
  • This is for 15.3.0, but you might find it helpful:
    // Scan Events
    static char * ble_scan_event_description[] =
    /* NRF_BLE_SCAN_EVT_FILTER_MATCH",        */ " 0 Filter matched in the multifilter mode",
    /* NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:    */ " 1 Request the whitelist from the main application",
    /* NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT: */ " 2 Device from the whitelist is found",
    /* NRF_BLE_SCAN_EVT_NOT_FOUND:            */ " 3 Filter not matched for the scan data",
    /* NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:         */ " 4 Scan timeout",
    /* NRF_BLE_SCAN_EVT_SCAN_REQ_REPORT:      */ " 5 Scan request report",
    /* NRF_BLE_SCAN_EVT_CONNECTING_ERROR:     */ " 6 Error occurred when establishing the connection from sd_ble_gap_connect",
    /* NRF_BLE_SCAN_EVT_CONNECTED:            */ " 7 Connected to device"
    #define NUM_BLE_SCAN_EVENTS (sizeof(ble_scan_event_description)/sizeof(ble_scan_event_description[0]))
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:     // Error occurred when establishing the connection. In this event, an error is passed from the function call @ref sd_ble_gap_connect
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:            // Connected to device
                  ble_gap_evt_connected_t const * p_connected = p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connect to Id %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:         // Scan timeout
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
             case NRF_BLE_SCAN_EVT_FILTER_MATCH:         // A filter is matched or all filters are matched in the multifilter mode
                   ble_gap_evt_adv_report_t const *p_adv_report = p_scan_evt->params.filter_match.p_adv_report;
                   NRF_LOG_INFO("Scan Match Id: %02x%02x%02x%02x%02x%02x",
                          p_adv_report->peer_addr.addr[0],
                          p_adv_report->peer_addr.addr[1],
                          p_adv_report->peer_addr.addr[2],
                          p_adv_report->peer_addr.addr[3],
                          p_adv_report->peer_addr.addr[4],
                          p_adv_report->peer_addr.addr[5]
             case NRF_BLE_SCAN_EVT_NOT_FOUND:            // The filter was not matched for the scan data
                   ble_gap_evt_adv_report_t const *p_not_found = p_scan_evt->params.p_not_found;
                   NRF_LOG_INFO("Deny Id: %02x%02x%02x%02x%02x%02x",
                          p_not_found->peer_addr.addr[0],
                          p_not_found->peer_addr.addr[1],
                          p_not_found->peer_addr.addr[2],
                          p_not_found->peer_addr.addr[3],
                          p_not_found->peer_addr.addr[4],
                          p_not_found->peer_addr.addr[5]
    //       case NRF_BLE_SCAN_EVT_FILTER_MATCH:         // A filter is matched or all filters are matched in the multifilter mode
             case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:    // Request the whitelist from the main application. For whitelist scanning to work, the whitelist must be set when this event occurs
             case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT: // Send notification to the main application when a device from the whitelist is found
    //       case NRF_BLE_SCAN_EVT_NOT_FOUND:            // The filter was not matched for the scan data
             case NRF_BLE_SCAN_EVT_SCAN_REQ_REPORT:      // Scan request report
                if (p_scan_evt->scan_evt_id < NUM_BLE_SCAN_EVENTS)
                   NRF_LOG_INFO("scan_evt_id: %d %s", p_scan_evt->scan_evt_id, ble_scan_event_description[p_scan_evt->scan_evt_id]);
                   NRF_LOG_INFO("Unhandled scan_evt_id: %d", p_scan_evt->scan_evt_id);
