Hi, i was interfacing oled with nrf52 board. I got some example and modified bit to use it with GCC. But it is now working. Oled not at all starting. oled is 0.96 inch, I2C based 128x64. Vdd = 5v sda = p0.26 scl = p0.27
Here is code github.com/.../
Thanks for correcting. Link is broken. Please share the link again. i have updated code in github. still not working.
An alternative if splitting the data does not work, is to use legacy TWI without EasyDMA. This can be selected by setting TWIx_USE_EASY_DMA 0 in sdk_config.h. Unfortunately the TWI master driver and HAL does not seem to have support for length parameters of more than 8 bits. You will have to change the driver/HAL implementations to support 16-bit lengths, or use the registers directly. I will check if I can make an example for you, but something like this code should work to do a TWI transfer using the registers:
uint32_t byte_number = 0;
NRF_TWI0->ENABLE = (TWI_ENABLE_ENABLE_Enabled << TWI_ENABLE_ENABLE_Pos);
NRF_TWI0->PSELSCL = 27;
NRF_TWI0->PSELSDA = 26;
NRF_TWI0->FREQUENCY = TWI_FREQUENCY_FREQUENCY_K100;
NRF_TWI0->INTENCLR = 0xFFFFFFFFUL; //Disable all interrupts
NRF_TWI0->SHORTS = 0x00000000;
NRF_TWI0->ADDRESS = 0x3C;
NRF_TWI0->EVENTS_TXDSENT = 0;
NRF_TWI0->TXD = 0x40; //control byte
NRF_TWI0->TASKS_STARTTX = 1;
while (byte_number < sizeof(buffer)) {
// wait for the transaction complete
while (NRF_TWI0->EVENTS_TXDSENT == 0);
NRF_TWI0->TXD = buffer[byte_number];
byte_number++;
while (NRF_TWI0->EVENTS_TXDSENT == 0); //Wait for last byte
NRF_TWI0->EVENTS_STOPPED = 0;
NRF_TWI0->TASKS_STOP = 1;
while (NRF_TWI0->EVENTS_STOPPED == 0);
hey do u get your answer?
i am also facing same type of problem
