How to Drive RGB LED with PWM
Hi Nordic Team, i am working on nrg52 to glow a RGB LED with white and Yellow colours. configured the RGB pins to three different Gpio (A2,A3,A4).
for this i am using PWM library example in which i can only configure 2 channel(2 pins) to drive PWM to Gpio pins. if i configure red and green pins using PWM i unable to get yellow color.
i am getting mixed colour of red,green, yellow. at wt fre quency(time period) i should operate PWM to get pure Yellow colour, and also how i can configure 3 pins to drive PWM using PWM library example.
here is my code.
APP_PWM_INSTANCE(pwm_library,1);                   // Create the instance "PWM1" using TIMER1.
static volatile bool ready_flag;            // A flag indicating PWM status.
void pwm_ready(uint32_t pwm_id)    // PWM callback function
    ready_flag = true;
uint32_t time_period = 2000L;
	ret_code_t err_code;
	 printf("VIBRATION:\r\n");
	    /* 2-channel PWM, 200Hz, output on DK LED pins. */
	    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(time_period, ARDUINO_2_PIN,ARDUINO_A4_PIN);
	    /* Switch the polarity of the second channel. */
	    pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
	    pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
	    /* Initialize and enable PWM. */
	    err_code = app_pwm_init(&pwm_library,&pwm1_cfg,pwm_ready);
	    app_pwm_enable(&pwm_library);
	    while(true){
for(int i = 0; i<= 100; i++){
	    app_pwm_channel_duty_set(&pwm_library, 0, i);
	    nrf_delay_ms(100);
  • void stop_LED_glow(){
    nrf_drv_pwm_stop(&m_pwm0,false);
    nrf_drv_pwm_uninit(&m_pwm0);
    //here R,G,B are dutycycle
    void start_update_pwm(){
    R = get_R();
    G = get_G();
    B = get_B();
    for (int i=0; i<100; i++){
    	reset_RGB_flag();
    	update_pwm(i*R,i*G,i*B);
    int main(void) {
    pwm_init();
    while(1){
    	start_update_pwm();
    	nrf_delay_ms(1000);
    	stop_LED_glow();
  • The pins will be set to 0 voltage after you call stop_LED_glow(), but if your RGB LED is active low, the RGB LED will still glow. You can try to set the pins high in the stop_LED_glow function to test this:
        nrf_gpio_cfg_output(gLEDR);
        nrf_gpio_pin_set(gLEDR);
        nrf_gpio_cfg_output(gLEDG);
        nrf_gpio_pin_set(gLEDG);
        nrf_gpio_cfg_output(gLEDB);
        nrf_gpio_pin_set(gLEDB);
