DFU OTA on a custom board using nrf51 DK board
I had done OTA DFU update on nrf51 DK Board using SDK11 version.
Now i wish to do same thing with other custom board which is having nrf51822QFAA. For that, my hardware connection is as per below.
   nrf51 DK                     nrf51822QFAA
   VTG + VDD                         VCC
   GND + GND                         GND
     SWDIO                          SWDIO
     SWDCLK                         SWDCLK
Then using nrfgo studio application, First erase then program softdevice and bootloader file of the SDK11. But no effect shown by my custom board.
If i have do same thing with nrf51 DK board and it's advtise its name DFUTEST and then i connect it for transfer my application using nrfconnect mobile application.
Please help me for solve it.
Thanks
  • Hello Sir,
    Thank you for your response.
    This is my Application file setting Xtal (MHz) -- "16.0" Operating system -- "None" ARM Compiler -- "Use default compiler version" Read/Only Memory Areas -- IROM1 (box is checked) Start-- "0x1B000" Size -- "0x25000" Startup (circle is checked) Read/Write Memory Areas -- IRAM1 (box is checked) Start -- "0x20002080" Size -- "0x5F80"
    and this is my bootloader setting Xtal (MHz) -- "16.0" Operating system -- "None" ARM Compiler -- "Use default compiler version" Read/Only Memory Areas -- IROM1 (box is checked) Start-- "0x3C000" Size -- "0x3C00" Startup (circle is checked) Read/Write Memory Areas -- IRAM1 (box is checked) Start -- "0x20002C00" Size -- "0x1380" IRAM2 (box is checked) Start --"0x20003F80" Size -- "0x80".
    Using this setting i can done successfully OTA update with SDK11.
    But when i trying to second time to update the my program i will stuck on starting bootloader message or if i am update the same file on nrf51DK. it is updated successfully.
  • Have you added DFU support to your application, see this Infocenter page. You need to add support for buttonless DFU, see this page, if you do not want to put the device in bootloader mode manually by pressing a button on the board.
  • Hello Sir,
    Now i had done OTA in both nrf51DK board and custom board.
    For my custom board, something happened new. When i burn both soft device and boot loader successfully my custom board advertised "DFUtarg" when i update my app.hex then it's changed as per my app.hex file.
    Now when i tried to second time to update my app.hex file its shown error message "DFU update failed" and suddenly advertised again "DFutarg".
    Or when i tried to update third time my app.hex file then its update successfully. Means First time OTA done successfully second time not and again third time done successfully.
    I don't know where i am making mistake.
  • Have you tried performing the same application update multiple times after the third successful update? Does all of them succeed or do you see one of the updates failing?
  • I am trying with the both multiple files or same files. But result is same.
