Please tell me, How to call Time() in milliseconds in Nordic nrf51822 ??
Hi Rakesh
As mentioned by Endnode it is quite simple to have one of the TIMER modules return the time elapsed in milliseconds.
I made a quick example for this based on the template example in the SDK:
#define MY_TIMER NRF_TIMER1
#define MY_TIMER_IRQn TIMER1_IRQn
#define MY_TIMER_IRQHandler TIMER1_IRQHandler
static uint32_t my_timer_seconds;
static void my_timer_start(void)
// Reset the second variable
my_timer_seconds = 0;
// Ensure the timer uses 24-bit bitmode or higher
MY_TIMER->BITMODE = TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos;
// Set the prescaler to 4, for a timer interval of 1 us (16M / 2^4)
MY_TIMER->PRESCALER = 4;
// Set the CC[0] register to hit after 1 second
MY_TIMER->CC[0] = 1000000;
// Make sure the timer clears after reaching CC[0]
MY_TIMER->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk;
// Trigger the interrupt when reaching CC[0]
MY_TIMER->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
// Set a low IRQ priority and enable interrupts for the timer module
NVIC_SetPriority(MY_TIMER_IRQn, 7);
NVIC_EnableIRQ(MY_TIMER_IRQn);
// Clear and start the timer
MY_TIMER->TASKS_CLEAR = 1;
MY_TIMER->TASKS_START = 1;
static uint32_t my_timer_get_ms(void)
// Store the current value of the timer in the CC[1] register, by triggering the capture task
MY_TIMER->TASKS_CAPTURE[1] = 1;
// Combine the state of the second variable with the current timer state, and return the result
return (my_timer_seconds * 1000) + (MY_TIMER->CC[1] / 1000);
static uint64_t my_timer_get_us(void)
return (uint64_t)my_timer_seconds * 1000000 + MY_TIMER->CC[1];
* @brief Function for application main entry.
// Enable LED_1
nrf_gpio_cfg_output(LED_1);
// Enable and start the timer
my_timer_start();
while (true)
// Toggle LED_1 every second based on the time value returned by my_timer_get_ms()
nrf_gpio_pin_write(LED_1, (my_timer_get_ms() / 1000) % 2);
// Timer interrupt handler
void MY_TIMER_IRQHandler(void)
if(MY_TIMER->EVENTS_COMPARE[0])
MY_TIMER->EVENTS_COMPARE[0] = 0;
// Increment the second variable
my_timer_seconds++;
Just copy/paste the above code into the template project if you want to try it out.
Best regards
Torbjørn
Can this code work for nrf52832 as well?
Hi
Yes, this code should run nicely on the nRF52832.
Looking at the code I think I wrote it for the nRF52832 in the first place, since I set the interrupt priority like this:
On the nRF51822 the lowest IRQ priority (highest number) is 3.
The code should work fine on both the nRF51 and the nRF52 series, since the IRQ priority is masked internally before it is set (so 7 will become 3 on the nRF51).
Best regards
Torbjørn
Could you also help me in understanding how do I print the time(with millisecond accuracy) on uart terminal.
Are you using the nrf_log module?
