Hello, Is it possible to use this:
for flashing the nrf52832 chip? if so how? is this thing the same as Jlink?
Great and simple idea to do it didn't think about it before though I still don't understand how programming the chip with segger ide(programming wise) and can't find any guides for nordic type of programming so the project is stuck.
I'd also like to ask, does the same apply for ST-LinkV3set?
Can I use it as well to program nRF52832?
Thanks
You can also try the IDAP-Link CMSIS-DAP. It comes with software to flash softdevice and dfu without the need of mergehex also supports parallel flashing for production.
Hi nirk,
where you able to figure it out? I created a custom programmer board using the STLINK-V3 module from ST.
When I want to upload a hex file to the attached NRF52810, I get the following output from openOcd:
C:\Users\david>openocd -f interface/stlink.cfg -f target/nrf52.cfg -c "reset_config none; program MyHexFile.ihex verify reset exit"
Open On-Chip Debugger 0.10.0 (2020-03-10) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
libusb1 09e75e98b4d9ea7909e8837b7a3f00dda4589dc3
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 1000 kHz
Info : STLINK v3 JTAG v5 API v3 SWIM v1 VID 0x0483 PID 0x374F
Info : using stlink api v3
Info : Target voltage: 2.568788
Info : Stlink adapter speed set to 1000 kHz
Error: jtag status contains invalid mode value - communication failure
Polling target nrf52.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Info : Previous state query failed, trying to reconnect
Examination failed, GDB will be halted. Polling again in 300ms
Info : Listening on port 3333 for gdb connections
** Unable to reset target **
shutdown command invoked
Interestingly, using an STLINK-V2 it works perfectly:
Info : STLINK v2 JTAG v35 API v2 SWIM v7 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 2.566820
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : Stlink adapter speed set to 950 kHz
Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x00000a80 msp: 0x20000400
** Programming Started **
Info : nRF52810-QFAA(build code: D0) 192kB Flash, 24kB RAM
Warn : Adding extra erase range, 0x00027280 .. 0x00027fff
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x2000001e msp: 0x20000400
** Programming Finished **
** Verify Started **
xPSR: 0x61000000 pc: 0x2000002e msp: 0x20000400
** Verified OK **
** Resetting Target **
However, using the STLINK-V3 for debugging/flashing STM32 microcontrollers works perfectly.
Thanks in advance
David
