What will the range be with a ble 5 server, but iphone with Bluetooth 4
If I used a nrf52840 bluetooth5 as a server, but customers have iPhones with Bluetooth 4.x on, will the range still be 2x or 4x, as stated by BT SIG?
Did Nordic test the range with Bluetooth 4.x phone?
I do not have a nrf52840 board yet.
I currently have 132 10040 nrf5283 device on my board, but the distance / range is not enough for the application. So I thought perhaps BLE5 will do the trick?
Any advise appreciated
  • Hi endnode, I just need to get from inside the house to anywhere in the backyard.
    Now, I lose the connection as soon as I walk in the backdoor.
    Perhaps BT classic would be the way to go, but I have invested so much effort into BLE so far.
    It will be really painful to go through this again switching to BR/EDR
    Regards
  • I see (and share your disappointment, working on similar topology where I expect to be able to cover a "average" house with BLE without such issues). Have you tried to play with Tx Power on nRF5x side? Can you debug it on nRF5x side and confirm what are RSSI values seen when iPhone approaches the edge of reliable zone? Can you run some sniffer at close proximity of the phone and see if it sees just half of connection events from certain moment (suggesting Tx power/antenna performance/Rx sensitivity issues on either side)? I'm afraid that the only advantage of switching to BR/EDR would be higher transmit power allowed (if I'm not mistaken) but who would like to learn completely different network stack, chip, APIs...
  • Btw. if you have two nRF5x boards (whatever variant and PCB type) I would suggest to set-up DTM test examples (as per nRF5 SDK) and run it on max Tx power (+4dBm). If you place devices to desired distance you could get from results (PER) some feeling where are real limits of the chip, if it has rather Tx issues or Rx. Of course iPhone will be always black-box in your game but still you have one side to optimize so I would try to find out if it's possible.
  • endnode,
    Thanks. I forgot about adjusting TX Power. I will try that next. I remember reading about it, so will try and see where and how to do that.
    Regards
  • Good news.
    I changed the TX power from (-8) to (+4), and now I can be inside the house, and BLE board in the far corner of the yard, and it stays connected.
    I noticed that If I move out of range, and lose connection, then move slightly closer and reconnect, the Services take longer to be displayed on the iPhone.
    I assume the weaker signal will cause more packet loss, so more retransmissions?
    Regards
