What is the passkey for gls example, and where is it set
I am using SDK13, 10040 nrf52832 s132
Any help appreciated
Does the GLS example use the same pin for the serial port as the other examples, such that the SDK will see it as a USB serial port? I use "good older" Hyperterminal to monitor the serial port, and it worked just fine with printf in the other demos as well as my own code. I'm on Win7, which doesn't come with HT any more, but I have copied HT from earlier versions and it works fine, once you get past a couple of startup glitches.
Disabling MITM protection per the define above does not work - there's no longer any visible connection attempt.
After many trials of many different things, suddenly the serial port began to work. If there's anything worse that something that stops working for no reason, it's got to be something that starts working for no reason! And I was able to see and enter a passkey, which apparently worked. After that, nothing. I need to now dig into the docs as I've gotten past the full-top issue. But I see the following sequence. Is the error message about adjusting RAM boundaries a real issue, and if so, how do I go about making that adjustment? Some linker script somewhere, perhaps?
Use putty my friend
Well for me it is "always" works and I don't need to change ANYTHING at all for the GLS example in sdk12. I use plain old armgcc and make and nothing else, no IAR, no SES, no Keil.
