Nordik UART app with Multiple service reception
I need to receive both UART Service data and HRS service data on the app.
Currently I have seen on Nordik Connect app , both the services can be found and can connect and receive data.
I need to do same with my app using nordik UART App code.
I have changed UART profile to HRS profile and code was working, i was receiving Nordik HRS service data.
But i want both services should be used and receives data. so i have prepare separate UARTService_HRS for hrs profile in the same code.also added needed changed.but it gives error null pointer exception on BLEGattService.
Please help
  • yes it is getting. I have debugged the code. service object get initialised.
  • If the service object is returned, have you check which characteristics are belong to that service ? You can call RxServiceHRS.getCharacteristics() to get the list.
    One thing I noticed from your code, you call :
      BluetoothGattCharacteristic TxCharHRS = RxService.getCharacteristic(RX_TSCHAR_UUID);
            if (TxCharHRS == null) {
                showMessage("Tx charateristic not found!");
                Log.d("no tx char ","Tx charateristic not found!");
                broadcastUpdate(DEVICE_DOES_NOT_SUPPORT_UART);
                return;
    Shouldn't it be:
      BluetoothGattCharacteristic TxCharHRS = RxServiceHRS.getCharacteristic(RX_TSCHAR_UUID);
                return;
    RxServiceHRS instead of RxService ?
  • yes , i have told already before your first comment. i have changed that code and replaced RxService by RxServiceHRS , so now it initialise service but now i had debug the code, i got both separate services and their own characteristics but still cant get TxCharHRS read
  • sorry but that comment is not updated. but i have thanks and i thought it is solved only because of null service it has problem
  • public void onCharacteristicRead(BluetoothGatt gatt, BluetoothGattCharacteristic characteristic, int status) { if (status == BluetoothGatt.GATT_SUCCESS) { broadcastUpdate(ACTION_DATA_AVAILABLE, characteristic); ListServices = gatt.getServices(); // gatt.readCharacteristic(chars.get(chars.size()-1)); gatt.readCharacteristic(Services.get(2).getCharacteristics().get(0)); gatt.readCharacteristic(Services.get(3).getCharacteristics().get(0)); //gatt.readCharacteristic(services.get(1).getCharacteristics().get(2)); // chars.remove(chars.get(chars.size()-1)); // if (chars.size() > 0) { // gatt.readCharacteristic(chars.get(chars.size()-1)); // } else { // gatt.disconnect(); // }
    I have tried to get read, but still is display some alohanumeric value. actually it should display byte array
