Nordik UART app with Multiple service reception
I need to receive both UART Service data and HRS service data on the app.
Currently I have seen on Nordik Connect app , both the services can be found and can connect and receive data.
I need to do same with my app using nordik UART App code.
I have changed UART profile to HRS profile and code was working, i was receiving Nordik HRS service data.
But i want both services should be used and receives data. so i have prepare separate UARTService_HRS for hrs profile in the same code.also added needed changed.but it gives error null pointer exception on BLEGattService.
Please help
  • but with same features it giving problem to iOS UART App. when both receiver characteristics notification is on, then transmission is very slow sometimes takes 2 seconds sometimes 10 seconds. doesn't understand how to handle this with ios
  • Adding delay isn't a very good solution. You can try: after you write to one service, you wait for the call back before you write to the second one.
  • but my current problem is when 2 characteristics from different services i have started notification on, my transmission on transmission characteristics goes on toss. can you help me understand how to get over it.
    I am developing App for iPhone UART service App.
    I have two services. Nordik UART Service and HRM service
    When I notify receiver characteristics of both services,my transmission characteristics taking delay of 2 to 10 seconds to transmit data.
    when i notify only single receiver characteristics, transmission works fine.but i start notify second receiver characteristics, transmission delayed.
    Please go through my below code for reception and transmission. How do i manage multiple services with multiple characteristics, i could not allow to have transmission delay.
    //Service Discovery Code:
    + (CBUUID *) uartServiceUUID
        return [CBUUID UUIDWithString:@"6e400001-b5a3-f393-e0a9-e50e24dcca9e"];
    + (CBUUID *) txCharacteristicUUID
        return [CBUUID UUIDWithString:@"6e400002-b5a3-f393-e0a9-e50e24dcca9e"];
    + (CBUUID *) rxCharacteristicUUID
        return [CBUUID UUIDWithString:@"6e400003-b5a3-f393-e0a9-e50e24dcca9e"];
    + (CBUUID *) torqueInformationServiceUUID
        return [CBUUID UUIDWithString:@"0000180D-0000-1000-8000-00805f9b34fb"];
    + (CBUUID *) torquerxCharacteristicUUID
        return [CBUUID UUIDWithString:@"00002A37-0000-1000-8000-00805f9b34fb"];
    - (UARTPeripheral *) initWithPeripheral:(CBPeripheral*)peripheral delegate:(id<UARTPeripheralDelegate>) delegate
        if (self = [super init])
            _peripheral = peripheral;
            _peripheral.delegate = self;
            _delegate = delegate;
    //        myperipheral=peripheral;
        return self;
    - (void) didConnect
    [_peripheral discoverServices:@[self.class.uartServiceUUID,self.class.torqueInformationServiceUUID]];
        NSLog(@"Did start service discovery.");
    - (void) didTSConnect
          NSLog(@" discovery start ,,,.........");
    - (void) peripheral:(CBPeripheral )peripheral didDiscoverServices:(NSError)error
        if (error)
            NSLog(@"Error discovering services: %@", error)
            return;
        for (CBService *service in peripheral.services)
            NSLog(@"Discovered service: %@", service.UUID);
            [peripheral discoverCharacteristics:nil forService:service];
         NSLog(@"Discovered service: %@", tsservice.UUID);
    - (void) peripheral:(CBPeripheral )peripheral didDiscoverCharacteristicsForService:(CBService )service error:(NSError *)error
       if (error)
            NSLog(@"Error discovering characteristics: %@", error);
            receptionStartFlag=false;
            return;
        for (CBCharacteristic *d in service.characteristics)
              if ([service.UUID isEqual:self.class.uartServiceUUID])
                    if ([d.UUID isEqual:self.class.rxCharacteristicUUID])
                        NSLog(@"Found RX characteristic");
                        self.rxCharacteristic = d;
                        rxChar=_rxCharacteristic;
                        [self.peripheral setNotifyValue:YES forCharacteristic:d];
                        [self.peripheral readValueForCharacteristic:d];
                    else   if ([d.UUID isEqual:self.class.txCharacteristicUUID])
                        NSLog(@"Found TX characteristic");
                        self.txCharacteristic = d;
                        txChar=_txCharacteristic;
            dispatch_async(dispatch_get_global_queue(DISPATCH_QUEUE_PRIORITY_HIGH,0),                     ^{
           if ([service.UUID isEqual:self.class.torqueInformationServiceUUID])
                if ([d.UUID isEqual:self.class.torquerxCharacteristicUUID])
                       NSLog(@"Found  TSRX characteristic");
                       rxChar=rxCharacteristic;
    - (void) peripheral:(CBPeripheral )peripheral didUpdateValueForCharacteristic:
    (CBCharacteristic )characteristic error:(NSError *)error
        if (error)
            NSLog(@"Error receiving notification for characteristic %@: %@",
            characteristic, error);
            return;
        //actual reception
        NSData *dataRec=self.rxCharacteristic.value;
        Byte byteData[[dataRec length]];//(Byte*)malloc(len);
        [dataRec getBytes:&byteData];
    //**Transmission Code**
    int8_t bytes2[] ={128,00,00,00,00,00,00,00,00,00,00,00,00};
                NSData *data2 = [NSData dataWithBytes:bytes2 length:sizeof(bytes2)];
                if ((txChar.properties & CBCharacteristicPropertyWrite) != 0)
                    [myperipheral writeValue:data2 forCharacteristic:txChar
                                        type:CBCharacteristicWriteWithResponse];
                else if ((txChar.properties & CBCharacteristicPropertyWrite) != 0)
                    NSLog(@"No write property on TX characteristic, %lu.", (unsigned
                    long)txChar.properties);
  • If you don't have a sniffer trace, I can't help you on this case. You should also print a log in your peripheral. The log should print out when it receive the notification enabling (CCCD writing) and when it start sending each notification.
