Hi
I am looking for some example code that shows best how to talk to a servo.. If there isn't any, any ideas which example project comes the closest ?
Thanks
J
Hi
Thanks
J
Hi
I am using the following code with no luck at all.. The servo refuses to move. I am 100% certain the hardware connections are correct and the servo does work.. Any ideas ? Here is my code:
BTW, I am using SDK 11.
int init_servo2(void)
ret_code_t err_code;
/* 2-channel PWM, 200Hz, output on DK LED pins. */
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(20000L, SERVO_PIN);
/* Switch the polarity of the second channel. */
pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
/* Initialize and enable PWM. */
err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
app_pwm_enable(&PWM1);
uint32_t value;
while(true)
for (uint8_t i = 0; i < 40; ++i)
value = (i < 20) ? (i * 5) : (100 - (i - 20) * 5);
ready_flag = false;
/* Set the duty cycle - keep trying until PWM is ready... */
while (app_pwm_channel_duty_set(&PWM1, 0, 10) == NRF_ERROR_BUSY);
/* ... or wait for callback. */
while(!ready_flag);
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, value));
nrf_delay_ms(125);
Try something like this:
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "app_error.h"
#include "bsp.h"
#include "nrf_delay.h"
#include "app_pwm.h"
APP_PWM_INSTANCE(PWM1,1); // Create the instance "PWM1" using TIMER1.
uint8_t SERVO_PIN = 4;
/* 1-channel PWM, 50Hz, output on DK LED pins, 20ms period */
/* Switch the polarity of the first channel. */
pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
err_code = app_pwm_init(&PWM1,&pwm1_cfg,NULL);
uint8_t servo_pos_max = 10;
uint8_t servo_pos_min = 5;
while (true)
while (app_pwm_channel_duty_set(&PWM1, 0, servo_pos_max) == NRF_ERROR_BUSY);
nrf_delay_ms(500);
while (app_pwm_channel_duty_set(&PWM1, 0, servo_pos_min) == NRF_ERROR_BUSY);
nrf_delay_ms(500);
Did you change the SERVO_PIN to the pin that you are using? I used pin 4 in the code I posted. You also have a nRF52-DK? If you run the code only on the DK, does it work then?
I had originally written that it was not working. But now with closer inspection something is happening. I have to put my ear to the servo and I can hear it clicking.. It's not moving, but it's clicking.. So I think we are in the right direction.
Any ideas how to get it to actually move ?
Are you testing with the DK now? Is the servo powered by the 5V output on the DK?
