Radio Notification events issue
i am using Nrf52840 with SDK 132 and version 13.
here is the initialization
 ble_radio_notification_init(APP_IRQ_PRIORITY_LOW, NRF_RADIO_NOTIFICATION_DISTANCE_5500US, Radio_Event);
this is Event Handler
void Radio_Event(bool radio_active)
	if (radio_active)
        	NRF_LOG_INFO("BLE STOP!\r\n");
 		    sd_ble_gap_adv_stop();
	        NRF_LOG_INFO(" Radio is inActive \r\n");
the problem is Active Radio and inActive Radio events Loop. First time, i got radio active event, inside active radio i used sd_ble_gap_adv_stop(); to stop the Advertising. then he should not give me any kind of event. but i got loop of active and inactive events. but in real there is no advertising after calling the sd_ble_gap_adv_stop();
Thank you
  • sd_ble_gap_adv_stop() is working inside the else.. i have one question, in the definition ble_radio_notification_init i also changes in Notification type from both to active and also inactive., when i made only on active then i got only one notification of active radio. but when i change a type to inactive then i got the both notification on active and also on inactive which i think is not correct.
    ok so, i am using the BLE Relay Program. when i switch off the scanning then regarding to notification every things look ok. but with scanning i got continuous notification of active and inactive. is there any way that i can only catch the advertising notification ?
  • That doesn't sound correct, but I think you should add a new question for that.
    Radio notification doesn't differentiate between a radio event caused by advertising or by scanning. Then I think you must measure how long the radio is on for, to figure out if it scanning or advertising.
