Can't get a callback from FDS no matter what - help!
I am able to initialize the module and get the callback , but when I try to write I will not get the callback after the write, and no errors.
If I simply try to read after write he will not find anything to read.
Please help, I'v been trying 2 days without any clue. I guess again there is some hidden parameter that nobody wrote on the docs.
This is the output :
:INFO:STARTED
:INFO:fds_evt_handler with :  0
:INFO: init good!
:INFO:Writing Record ID = 1
:INFO:Writing Record ID = 2
This is the program :
 static void fds_evt_handler(fds_evt_t const * const p_fds_evt)
       // ****this line will log ONLY on init event, not on write event
       NRF_LOG_INFO("fds_evt_handler with :  %d\r\n",p_fds_evt->id);
        switch (p_fds_evt->id)
            case FDS_EVT_INIT:
                if (p_fds_evt->result != FDS_SUCCESS)
                     NRF_LOG_INFO("failed initializing\r\n");
                   NRF_LOG_INFO(" init good!\r\n");
                   init_flag=1;
           case FDS_EVT_WRITE:
              write_flag=1;
               if (p_fds_evt->result == FDS_SUCCESS)
                    {  NRF_LOG_INFO("finish write\r\n"); }
                    { NRF_LOG_INFO("failed write with %d \r\n",p_fds_evt->result); }
            case FDS_EVT_UPDATE:
               write_flag=1;
                      {NRF_LOG_INFO("finish write\r\n"); }
                    { NRF_LOG_INFO("failed updated with %d \r\n",p_fds_evt->result); }
    void initStorage()
            ret_code_t ret = fds_register(fds_evt_handler);
            if (ret != FDS_SUCCESS)
                NRF_LOG_INFO("FAILED TO INIT STORAGE\r\n");
            ret = fds_init();
                NRF_LOG_INFO("ERROR INIT\r\n");
      void  write()
    	        #define FILE_ID     0x1111
    		#define REC_KEY     0x2222
    		static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
    		fds_record_t        record;
    		fds_record_desc_t   record_desc;
    		fds_record_chunk_t  record_chunk;
    		// Set up data.
    		record_chunk.p_data         = m_deadbeef;
    		record_chunk.length_words   = 2;
    		// Set up record.
    		record.file_id              = FILE_ID;
    		record.key              		= REC_KEY;
    		record.data.p_chunks       = &record_chunk;
    		record.data.num_chunks   = 1;
    		ret_code_t ret = fds_record_write(&record_desc, &record);
    	          NRF_LOG_INFO("failed write with %d \r\n",ret);
    		 NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
    				NRF_LOG_INFO("ERROR WROTE WITH %d\r\n",ret);
    void read ()
                     NRF_LOG_INFO("START READING\r\n");
    		fds_flash_record_t  flash_record;
    		fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
    		uint32_t *data;
    		uint32_t err_code;
    		// Loop until all records with the given key and file ID have been found.
    		while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
    				err_code = fds_record_open(&record_desc, &flash_record);
    				if ( err_code != FDS_SUCCESS)
                                       NRF_LOG_INFO("error read: %d\r\n",err_code);
    				NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
    				NRF_LOG_INFO("Data = ");
    				data = (uint32_t *) flash_record.p_data;
    				for (uint8_t i=0;i<flash_record.p_header->tl.length_words;i++)
    					NRF_LOG_INFO("0x%8x ",data[i]);
    				NRF_LOG_INFO("\r\n");
    				// Access the record through the flash_record structure.
    				// Close the record when done.
    				err_code = fds_record_close(&record_desc);
    				if (err_code != FDS_SUCCESS)
     void find_and_delete (void)
    		fds_find_token_t    ftok;
    		ftok.page=0;
    		ftok.p_addr=NULL;
    		// Loop and find records with same ID and rec key and mark them as deleted.
    			fds_record_delete(&record_desc);
    			NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
    		ret_code_t ret = fds_gc();
                          NRF_LOG_INFO("error find: %d\r\n",ret);
 static void sys_evt_dispatch(uint32_t sys_evt)
    fs_sys_event_handler(sys_evt);
            log_init();
            NRF_LOG_INFO("STARTED\r\n");
             setupBluetoothWithDelegate(BluetoothDelegate);
                // fds
                   initStorage();
    		find_and_delete();
    		 write();
    		//wait until the write is finished.
    		while (write_flag==0);
    		read();
           advertise();
            for (;;)
              power_manage();
