Pwm minimum frequency setting
hi, I would like to use pwm to output the 1HZ waveform to drive the motor, but when I set the frequency to be 1HZ, I can not find the device and cause 51822 to reset. This is my code:
    Motor_Pwm_Init(1000000,1,1);
    Motor_Duty_Set(50,50);
    void Motor_Pwm_Init(uint32_t freq,uint32_t MotorLeft_Polarity,uint32_t MotorRight_Polarity)
	uint32_t err_code;
	app_pwm_disable(&PWM1);
	app_pwm_uninit(&PWM1);
	app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(freq,MOTOR_LEFT_PIN,MOTOT_RIGHT_PIN);   //set pwm frequency
	pwm1_cfg.pin_polarity[0] = MotorLeft_Polarity;					//Polarity of active state on pin.
    pwm1_cfg.pin_polarity[1] = MotorRight_Polarity;
	err_code = app_pwm_init(&PWM1,&pwm1_cfg,NULL);																						//  Init the PWM
	app_pwm_enable(&PWM1);
    uint8_t Motor_Duty_Set(uint32_t DutyLeft,uint32_t DutyRight)
	uint8_t TimeOut = 0;
	wdt_feed();
	while (app_pwm_channel_duty_set(&PWM1,(uint8_t) 0, DutyLeft) == NRF_ERROR_BUSY)
  • I used the pwm_library example in the SDK. This is the main.c code I used:
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "app_error.h"
    #include "bsp.h"
    #include "nrf_delay.h"
    #include "app_pwm.h"
    APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
        uint32_t err_code;
        app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(freq,3,4);   //set pwm frequency
        //wdt_feed();
        while (app_pwm_channel_duty_set(&PWM1,(uint8_t) 1, DutyLeft) == NRF_ERROR_BUSY)
        while (true)
  • Through repeated tests, I found the problem is that when I only set a pin of duty, it is working properly, but the two set at the same time duty, the program stuck, and then reset
    { uint8_t TimeOut = 0; //wdt_feed(); while (app_pwm_channel_duty_set(&PWM1,(uint8_t) 0, DutyLeft) == NRF_ERROR_BUSY) { wdt_feed(); #if 0 if(TimeOut ++ > 200) { TimeOut = 0; return 0; } #endif }
    wdt_feed();
    #if 0
    while (app_pwm_channel_duty_set(&PWM1,(uint8_t) 1, DutyRight) == NRF_ERROR_BUSY)
    	#if 0
    		TimeOut = 0;
    		return 0;
    //wdt_feed();
    //return 1;
    So that you can work and output the correct 1hz waveform, should I only open the left, the right side of the code shielded
    But when I try to set the duty cycle of both channels, the device is reset, the code is as follows
    wdt_feed();
    #if 1
    	#if 0
    		TimeOut = 0;
    		return 0;
    //wdt_feed();
    //return 1;
    enter code here
  • Could it be a timeout from the WDT that is causing the issues?
    See this post about how to debug and find the reason for the reset.
