Serial port interrupt
I have a serial port set upp with the serial port library like this:
#define UART_PIN_DISCONNECTED           0xFFFFFFFF /**< Value indicating that no pin is connected to this UART register. */
#define RX_PIN_NUMBER                   7
#define TX_PIN_NUMBER                   8
#define CTS_PIN_NUMBER                  UART_PIN_DISCONNECTED
#define RTS_PIN_NUMBER                  UART_PIN_DISCONNECTED
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                      RX_PIN_NUMBER, TX_PIN_NUMBER,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_9600,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 32
NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_UART_DEF(serial_uart, 0);
NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ,
                      &serial_queues, &serial_buffs, on_serial_evt, sleep_handler);
and in main:
ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
In on_serial_evt i have the following code:
case NRF_SERIAL_EVENT_RX_DATA:
        err_code = app_sched_event_put(NULL, NULL, on_serial_evt_handler);
        NRF_LOG_INFO("NRF_SERIAL_EVENT_RX_DATA\r\n");
And finally in on_serial_evt_handler:
static void on_serial_evt_handler()
    NRF_LOG_INFO("handler\r\n")
    ret_code_t err_code;
    uint8_t c[26];
    memset(c, 0, sizeof(c));
    size_t p_read;
    err_code = nrf_serial_read(&serial_uart, c, sizeof(c), &p_read, 3000);
    NRF_LOG_INFO("p_read:%d\r\n", p_read);
    NRF_LOG_INFO("c[0]:%c\r\n", c[0]);
    NRF_LOG_INFO("error%d\r\n", err_code);
When I start the app everything works as expected with nothing happening. Then I send 1 byte of data to the mcu and the NRF_SERIAL_EVENT_RX_DATA event gets triggered. I can then read the data as expected. Now the problem is that the nrf_serial_read seems to trigger another NRF_SERIAL_EVENT_RX_DATA event. This results in a infinite loop of 0's recieved and the . No matter if i set the timeout of nrf_serial_read to 0 it still always returns NRF_ERROR_TIMEOUT.
I understand the need for triggering NRF_SERIAL_EVENT_RX_DATA if i use none blocking mode but then how can i tell the difference between "new data in buffer" and "data fetched by nrf_serial_read ready"?
I use a nRF52832_xxaa with sdk 13 and S132 4.0.2.
Thankful for any pointers!
  • Thank you guys for support -if I'm understand well my code should looks like below:
    //In case where:
    /*NRF_SERIAL_CONFIG_DEF(serial_config,
                            &serial_queues,
                            &serial_buffs,
                            NULL,
                            sleep_handler);*/
    static void serial_event_handler(struct nrf_serial_s const *p_serial, nrf_serial_event_t event) {
        if (event == NRF_SERIAL_EVENT_RX_DATA) {
            char c;
            APP_ERROR_CHECK(nrf_serial_read(&serial_uart, &c, sizeof(c), NULL, 0));
            //copy data to buff array
            //clear c
    of course in case when I want to read every single char and add it to some buffer yes ?
  • Are we sure this is how it's supposed to be done? Reading from the serial with nrf_serial_read won't dispatch another event handler upon reception? I think reading from the queue is the way to go?
