Error when programming a custom board using nRF52-DK
Dear colleagues,
I am trying to erase / program the custom board ( with nRF52832 SoC installed) using nRF52-DK. The setup looks like that:
nRF52-DK Custom / External Board
VDD ------+-------------> VDD
VTG ----+/
GND ------------------------> GND
GND DETECT -----/
SWD IO -----------------> SWD IO
SWD CLK ----------------> SWD CLK
image description
As the picture shows, the custom board nRF52-DK is powered from USB, and the custom board is powered from the nRF52-DK. The voltage on VDD (P20), VTG (P20), and external board is 2.86V. The voltage on SWDCLC and SWDIO (P20) is 2.63V.
When I try to use nRFGO, the program just reloads whenever I click on motherboard's name. When I try to use nrfjprog, it shows the following error in log file:
image description
When I try to connect using JLinkExe, it shows the error:
image description
The schematic of the custom board is represented on the picture bellow: image description
I will appreciate any help!
P.S. programming the nRF52-DK (without custom board) works just fine.
UPDATE: when I power the custom board from the external power supply:
  1. custom board and DK not connected:
  • voltage at DK: VDD - 2.88V, VTG - 0, SWDIO-2.65V, SWDCLC-2.65V
  • voltage at custom board: VDD - 3.26V, SWDIO-3.21V, SWDCLC-0V
  1. custom board and DK are connected
VTG ------+-------------> VDD
GND DETECT -----/
image description
  • VTG - 3.26V, SWDIO: 3.30V, SWDCLC - 0.52V on both
  • if I disconnect SWDCLCs, when SWDCLC at DK is 3.56V, at custom board - 0V
  • if I disconnect SWDIOS, when SWDIO at DK is 3.56V, at custom board - 3.21V
The setup was tested with another nRF52-DK and it also did not work, so DK is not the problem.
The closer photo of how the chip is mounted is attached: DSC00364.png
  • Well then it looks like voltmeter is OK. No chance to run nrfjprog or nRFgo Studio on different machine (with Windows)?
  • We already did it on Windows machine but also did not have luck with it :( Today I will try to power the custom board with 12V and see if it will help
  • I tried to power the custom board from 12V as you suggested, but it still did not work. I updated the question with voltage levels when the custom board is powered from the external power supply.
  • You don't need GND DETECT, just connect VTG to VDD, SWD pins and power pins from the DK to your custom board.
  • Maybe not needed but they don't harm (= if GND Detect is grounded it should not exhibit errors like Artem reports).
1 2 3 4 5
