How to create a whitelist on the Central device
I want to create a whitelist on the Central device. Because there is a lot of peripheral devices around and I just want to connect one peripheral device. First I register the address of the central device to the peripheral device. When I work with a single peripheral device and a single central device, I can send commands from the central device to the peripheral device. But when I have more than one peripheral device in the vicinity, I can not send commands to the peripheral device registered from the central device. So I decided to create whitelist on the central device to connect the peripheral device which I registered before. But I don't know how. Do you have any example? (except ble_app_hrs)
Function to start scanning code;
// Function to start scanning
void scan_start(void) {
  ble_gap_whitelist_t   whitelist;
  ble_gap_addr_t      * p_whitelist_addr[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
  ble_gap_irk_t       * p_whitelist_irk[BLE_GAP_WHITELIST_IRK_MAX_COUNT];
  uint32_t              err_code;
  uint32_t              count;
  err_code = pstorage_access_status_get(&count);
  if (count != 0)
      m_memory_access_in_progress = true;
      return;
  // Initialize whitelist parameters.
  whitelist.addr_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
  whitelist.irk_count  = 0;
  whitelist.pp_addrs   = p_whitelist_addr;
  whitelist.pp_irks    = p_whitelist_irk;
  // Request creating of whitelist.
  err_code = dm_whitelist_create(&m_dm_app_id,&whitelist);
  if (((whitelist.addr_count == 0) && (whitelist.irk_count == 0)) ||
      (m_scan_mode != BLE_WHITELIST_SCAN)                        ||
      (m_whitelist_temporarily_disabled))
      APPL_LOG("THERE IS NO WHITELIST\r\n");		//Debug Note
      // No devices in whitelist, hence non selective performed.
      m_scan_param.active       = SCAN_ACTIVE;        // Active scanning set.
      m_scan_param.selective    = SCAN_SELECTIVE;     // Selective scanning not set.
      m_scan_param.interval     = SCAN_INTERVAL;			// Scan interval.
      m_scan_param.window       = SCAN_WINDOW;  			// Scan window.
      m_scan_param.p_whitelist  = NULL;        				// No whitelist provided.
      m_scan_param.timeout      = 0x0000;       			// No timeout.
      APPL_LOG("WHITELIST WAS FOUND\r\n");		//Debug Note
      // Selective scanning based on whitelist first.
      m_scan_param.active       = 1;            // Active scanning set.
      m_scan_param.selective    = 1;            // Selective scanning not set.
      m_scan_param.interval     = SCAN_INTERVAL;// Scan interval.
      m_scan_param.p_whitelist  = &whitelist;   // Provide whitelist.
      m_scan_param.timeout      = 0x001E;       // 30 seconds timeout.
      m_scan_mode = BLE_WHITELIST_SCAN;
  err_code = sd_ble_gap_scan_start(&m_scan_param);
