How should you test the capacitive touch library?
I was able to write the code and put it to work on AN5 pin , and I found out that whenever I approach to the DK board he see it as a touch.
I connected to the pin a 10cm exposed wire, and when i touch it nothing happens, only when I touch the plastic of the connector.
What kind of touch the library expect ?
I am trying to understand in terms of hardware, what really is going on here ? should I touch directly the analog pin , or should it be through an isolator ?
and how to make it faster ? what are the tresh holds values means ( of 400 ) ?
Thanks a lot.
