nRF52 DK (pca10040) not seen by nrfjprog after IF update
After spending half a day on this solution, I found out it wasn't really a solution - it devolved back to the same issue after trying to connect - please advise!
Description of System: nRF52 DK Windows 10 pro PC
Description of Problem: Basically, my DK appears bricked, and none of the established solutions work.
After flashing a couple different softdevices on the nRF52 DK, it was no longer found by the nrfjprog utility, whether in regular or bootloader modes.
At first, powering on in bootloader mode would consistently cause the BOOTLOADER drive to show up then disappear either instantly or after ten seconds or so. Trying to flash or drag/drop any FW during this time (for example the latest recommended nRF5x-OB-JLink-IF) was futile. After installing MBED drivers, it wouldn't show up at all as a drive or a COM/PORT entry in the device manager either.
Taking any of the normal steps either requires nrfjprog CLI to be working (the device shows up as recognized) or the device to show up and function properly with a drag and drop. Restarting the computer did not help. All drivers are up to date, and everything has been uninstalled and reinstalled.
My thoughts are that this is either a driver problem or a serious corruption in the board FW that disallows communication. I have an external J-Link programmer if someone could guide me through reflashing with that via the JTAG micro-header interface.
After manually uninstalling all drivers related to the J-Link then reinstalling from scratch, the drive does now show up, and I was able to then use command prompt to copy the IF onto the BOOTLOADER drive, which subsequently started to show up when not in bootloader mode as JLINK (still as BOOTLOADER when started in that mode). I am still, however, unable to see the device with nrfjprog.
Update: In the interest of trying all available options, I tried setting up and ident with Keil, no luck. Also tried sandeepmistry's arduino library - and it actually can see the device (and reads correct serial number). Turns out it will actually program the thing. So now I am beyond confused, because the last thing I expected to work - the most abstracted one - seems to work fine. Any way I can get it showing up again in nrfjprog so that I can hopefully start using this with Make and eventually Eclipse?
Thanks so much in advance.
  • It turns out there's another issue that was lurking behind this one, and it's in the USB driver. This separate issue is what was causing the device not to be seen by nrfjprog. I ran into it again, and fortunately it was relatively easy to fix - just going to "Universal Serial Bus devices" in Device Manager and uninstalling JLink there then unplugging and replugging did the trick. Not sure what caused the issue itself, but this is good to keep in mind if you have this problem.
