how to make communication between two stm8s+nrf24l01 (ie.one(stm8s+nrf24l01) as transmitter and one(stm8s+nrf24l01) as receiver)?can anyone help
hello , i am trying to make communication between two (stm8s+nrf24l01) modules for which i am using this link zewaren.net/.../110, by this code i am able to transmit data from one side and receive data to the another side but it can happen only one next time i will not able to send data and receive data. can anyone please tell me why it is happening by refering this code. or if anyone had made this communication then will you please share your code.or give me suggestions. controller:stm8s and nrf24l01 IDE:IAR workbench
Thank you
Pallavi
  • hello sir, Thank you fr the elaboration about the conceptI am working on another project now.so the project on stm8s+nrf24l01 i have kept on hold.when i started working on this project based on stm8s+nrf24l01 will continue this discussion.At that time i need help.
    Thank You,
    Pallavi
  • hello ,
    i found the code of nrf24l01+STM8s..the code is written by doing bitbanging.
    the code for transmitter is,
    ////////////////MASTER////////////////
    //#include <iostm8S105c6.h>
    #define multiplier 4
    #define DISCOVERY 1
    #if defined DISCOVERY
    #elif defined PROTOMODULE
    #include <iostm8s103k3.h>
    #else
        #include <iostm8s103f3.h>
    #include <intrinsics.h>
    #define         CE       PD_ODR_ODR3
    #define         CSN      PD_ODR_ODR2
    #define         SCK      PC_ODR_ODR7
    #define         MOSI     PC_ODR_ODR6
    #define         MISO     PC_IDR_IDR5
    #define         IRQ      PD_IDR_IDR4
    #define TX_ADR_WIDTH    5    // 5 uints TX address width
    #define RX_ADR_WIDTH    5    // 5 uints RX address width
    #define TX_PLOAD_WIDTH  32  // 20 uints TX payload
    #define RX_PLOAD_WIDTH  32   // 20 uints TX payload
    unsigned char  TX_ADDRESS[TX_ADR_WIDTH]= {0xE7,0xE7,0xE7,0xE7,0xE7};
    unsigned char  RX_ADDRESS[RX_ADR_WIDTH]= {0xE7,0xE7,0xE7,0xE7,0xE7};
    /////////////// SPI(NRF24l01) commands////////////////
    #define READ_REG        0x00
    #define WRITE_REG       0x20
    #define RD_RX_PLOAD     0x61
    #define WR_TX_PLOAD     0xA0
    #define FLUSH_TX        0xE1
    #define FLUSH_RX        0xE2
    #define REUSE_TX_PL     0xE3
    #define NOP             0xFF
    ///////////////SPI(nrf24l01) registers///////////////////////////////////////
    #define CONFIG          0x00
    #define EN_AA           0x01
    #define EN_RXADDR       0x02
    #define SETUP_AW        0x03
    #define SETUP_RETR      0x04
    #define RF_CH           0x05
    #define RF_SETUP        0x06
    #define STATUS          0x07
    #define OBSERVE_TX      0x08
    #define CD              0x09
    #define RX_ADDR_P0      0x0A
    #define RX_ADDR_P1      0x0B
    #define RX_ADDR_P2      0x0C
    #define RX_ADDR_P3      0x0D
    #define RX_ADDR_P4      0x0E
    #define RX_ADDR_P5      0x0F
    #define TX_ADDR         0x10
    #define RX_PW_P0        0x11
    #define RX_PW_P1        0x12
    #define RX_PW_P2        0x13
    #define RX_PW_P3        0x14
    #define RX_PW_P4        0x15
    #define RX_PW_P5        0x16
    #define FIFO_STATUS     0x17
    unsigned char    sta=0x00;
    #define   RX_DR  (sta & 0x40)
    #define   TX_DS  (sta & 0x20)
    #define   MAX_RT  (sta & 0x10)
     void init_io_config()
       PC_DDR_DDR5=0;
       PC_DDR_DDR6=1;
       PC_DDR_DDR7=1;
       PD_DDR_DDR2=1;
       PD_DDR_DDR3=1;
       PD_DDR_DDR4=0;
       PC_CR1_C15=1;
       PC_CR1_C16=1;
       PC_CR1_C17=1;
       PD_CR1_C12=1;
       PD_CR1_C13=1;
       PD_CR1_C14=0;
       PC_CR2 = 0x00;
       PD_CR2 = 0x00;
     void delayms(unsigned int count)
     unsigned int i,j;
     for(i=0;i<count;i++)
     for(j=0;j<450;j++);
    unsigned char SPI_RW(unsigned char byte)
        unsigned char i;
        for(i=0;i<8;i++) // output 8-bit
          MOSI=(byte & 0x80);
          byte = (byte << 1);
          SCK = 1;
          byte|=MISO;
          SCK = 0;
        return (byte);
    unsigned char SPI_RW_Reg(unsigned char reg, unsigned char value)
     unsigned int  status;
     CSN = 0;                   // CSN low, init SPI transaction
     status = SPI_RW(reg);      // select register
     SPI_RW(value);             // ..and write value to it..
     CSN = 1;                   // CSN high again
     return(status);            // return nRF24L01 status uchar
    unsigned char SPI_Write_Buf(unsigned char reg, unsigned char *pBuf, unsigned char num)
     unsigned char status=0x00,byte_ctr=0;
     CSN = 0;
     for(byte_ctr=0; byte_ctr < num; byte_ctr++)
       SPI_RW(*pBuf++);
     CSN = 1;
     return(status);
    void init_NRF24L01(void)
      delayms(1);
      CE=0;    // chip enable
      CSN=1;   // Spi disable
      SCK=0;   // Spi clock line init high
     SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); //set pwr up bit enable
     SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
     SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH);
     SPI_RW_Reg(WRITE_REG + EN_AA, 0x00);
     SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);   // enable pipe 0
     SPI_RW_Reg(WRITE_REG + SETUP_AW, 0x02);    // set up address width 5 bytes
     SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x00);  // retransmission disabled
     SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   //pwr=0dbm,datarate =1 mbps,lna:hcurr
     SPI_RW_Reg(WRITE_REG + STATUS, 0x02);          //
      SPI_RW_Reg(WRITE_REG + RF_CH, 0x2c);          //
     SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //
     CE=1;               //make ce high
    void SetTX_Mode(void)
     CE=0;
     SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);
     CE = 1;
     delayms(1);
    void nRF24L01_TxPacket(unsigned char * tx_buf)
     CE=0;
     SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
     SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);
     //while(TX_DS!=1);
     //SPI_RW_Reg(WRITE_REG + STATUS, 0x00);
     CE=1;
    delayms(1);
     //sta = SPI_RW(STATUS);
    void SetRX_Mode(void)
     CE=0;
     CE = 1;
     delayms(1);
    unsigned char SPI_Read_Buf(unsigned char reg, unsigned char *pBuf, unsigned char num)
     unsigned char  status,byte_ctr=0;
     CSN = 0;                      // Set CSN low, init SPI tranaction
     status = SPI_RW(reg);         // Select register to write to and read status uchar
     for(byte_ctr=0;byte_ctr < num; byte_ctr++)
     pBuf[byte_ctr] = SPI_RW(0);
     CSN = 1;
    unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
      unsigned char revale=0;
      CE = 1;
      sta=SPI_RW(STATUS);
      while(RX_DR);
      if(RX_DR)
      CE = 0;
      SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
      revale =1;
     return revale;
    void main()
      unsigned char TxBuf[32]={0};
    //unsigned char RxBuf[32]={0};
      init_io_config();
      init_NRF24L01() ;
      while(1)
      TxBuf[1] =0x55;
      SetTX_Mode();
      nRF24L01_TxPacket(TxBuf);
      TxBuf[2]=0x00;
     for(int i=0;i<2000;i++)
       for(int j=0;j<1275;j++);
      delayms(500);
     /* SetRX_Mode();
      nRF24L01_RxPacket(RxBuf);*/
    for which i am using stm8s discovery board and iAR workbench.will you please tell me is this a right program as a transmitter
    Thank you,
    Pallavi
  • and for this receiver code is,
    #define DISCOVERY 1
    #else
    #define NOP             0xFF
    #define CONFIG          0x00
    #define EN_AA           0x01
    #define RF_CH           0x05
    #define STATUS          0x07
    #define CD              0x09
    unsigned char    sta;
       PC_DDR_DDR5=0;
       PC_DDR_DDR6=1;
       PC_DDR_DDR7=1;
       PD_DDR_DDR2=1;
       PD_DDR_DDR3=1;
       PD_DDR_DDR4=0;
       PC_CR1_C15=1;
       PC_CR1_C16=1;
       PC_CR1_C17=1;
       PD_CR1_C12=1;
       PD_CR1_C13=1;
       PD_CR1_C14=0;
       PC_CR2 = 0x00;
       PD_CR2 = 0x00;
     unsigned int i,j;
     for(j=0;j<450;j++);
        unsigned char i;
          MOSI=(byte & 0x80);
          byte = (byte << 1);
          SCK = 1;
          byte|=MISO;
          SCK = 0;
        return (byte);
     CSN = 0;
         SPI_RW(*pBuf++);
     CSN = 1;
     return(status);
      delayms(1);
     CE=0;
     CE = 1;
     delayms(1);
     CE=0;
     sta=SPI_RW(STATUS);
     while(TX_DS!=1);
     CE=1;
     delayms(2);
     CE=0;
     CE=0;
     CE = 1;
     delayms(1);
     CSN = 1;
      CE = 1;
      sta=SPI_RW(STATUS);
      while(RX_DR);
      if(RX_DR)
      CE = 0;
      revale =1;
     return revale;
    void main()
      init_io_config();
      init_NRF24L01() ;
     /* TxBuf[1] =0x55;
      SetTX_Mode();
        delayms(500);
      SetRX_Mode();
    Do you think it is right?
  • Hi Pallavi
    I have no experience with the ST solution unfortunately.
    What is the difference between this implementation and the Arduino project you worked on earlier?
    Assuming the Arduino board is working fine with the nRF24L01 module you should be able to use that as a reference to figure out what is going wrong here.
    Best regards
    Torbjørn
