HELP! I cannot change the value of a variable???
nrf52840, S140.
So for the past 1 or 2 weeks I have been fighting with this problem:
Now it turned out that the connection handle may actually be INVALID, it's 0!
So I debugged the wind out of the whole thing and found that I cannot change the value of the active connection handle"m_active_conn_handle", which I use to pass as the active connection handle to a variety of functions including for example sd_ble_hvx().
Here is the program:
else if (p_ble_evt->header.evt_id == BLE_GAP_EVT_CONNECTED)
		uint32_t* error_code = &m_active_conn_handle;
		m_active_conn_handle = (uint16_t)p_ble_evt->evt.gap_evt.conn_handle;
		//m_active_conn_handle = 0x1234;
		error_code = sd_ble_gatts_sys_attr_set(p_ble_evt->evt.gatts_evt.conn_handle, NULL, 0, 0);
I set a breakpoint at:
m_active_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
and then pressed F10. Instead of the right value (0x8e4), the m_active_conn_handle got set to 0x0000.
This is really strange? Making an uneducated guess, is this caused by allocating m_active_conn_handle at the wrong address, like some sort of read only RAM region? Or stack region? Or is this caused by RAM_BASE_ADDRESS not configured properly?
Also, a lot of error code won't show unless I play some "tricks", for example:
err_code = sd_ble_gatts_hvx(m_active_conn_handle, &hvx_params);
the err_code will not show when breakpointed, it will simply display "out of scope" in keil's watch window but if I write:
err_code_address = & err_code;
below it, and set the breakpoint there, the err_code_address will NOT display the address of err_code, still "out of scope", but err_code will now properly display if you move your mouse cursor over it!
All of these lead me to believe I have set certain memory address wrong, but then again, that's just my uneducated guess, here is my config in the magic wand:
image description image description
Also, when calling
error_code = sd_ble_enable(&ble_enable,&USER_APP_RAM_BASE);
I'm using USER_APP_RAM_BASE = 0, which I know is a really, really bad idea but I can't modify its value to anything other than that either, for the same reason I can't modify the active connection handle's value.
Can someone please tell me what the whirlwind is going on??? Please help! Many thanks!
edit @endnode can you help me??
Edit: Quick answer: turn off optimization, and the problems "unable to change value, values not properly being displayed etc. are all gone.
  • @Alex Hi, I'm trying to figure out how to see if the cccd handle were properly set or not.
  • if you want to actually debug at the source level as opposed to the assembler level then yes you should turn O3 off. That is why you're seeing garbage values in the debugger, it just doesn't have a way to work out where the variables are so it shows crap. In non optimised mode each variable in the frame is given a place on the stack and it's slavishly copied to there and from there each time it's used, that's how the debugger shows it. I don't really know why you're using O3 for code you're trying to debug, you're just making life hard for yourself.
