I have two square waveforms coming out of a pin each. I want to measure the delay between them. Which command should I use? How can I do this?
Thank you very much!
Hi Jørgen, Could you help me please with another thing? The code you sent me as an example uses the version of SDK 12.3, but I need it in version 11. How can I do this? Can you send me the same example in version 11 of SDK, please?!
Thank you Best wishes, B.
Updated above answer with SDK 11 version. Note that only Keil project is updated with correct files.
Thank you very much again!!!! The sdk 11 version is compiling and it sends data to the log. It crashes after some time though.. it’s not sending data continuously as the sdk 12 version did. How could I correct it?
Try debugging to see which function is returning non-zero error code.
