when trying to initialize the nrf52...little bit confused how to specifically address a pin for i2c....can anyone help me with a piece of code. Thank you in advance.
TWI sensor example should work fine, but you need to modify it to read and write the correct registers.
yes..m just trying to read revision id register (0x81)...it is supposed to return 21..i am new to twi
* Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup tw_sensor_example main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Common addresses definition for temperature sensor. */
#define vcnl4020_ADDR (0x13U>>1)
#define vcnl4020_REG_command 0x80U
#define vcnl4020_REG_PRODUCT_ID_REVISION_REGISTER 0x81U
#define LM75B_REG_THYST 0x02U
#define LM75B_REG_TOS 0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
* @brief Function for setting active mode on MMA7660 accelerometer.
ret_code_t vcnl4020_set_mode()
ret_code_t err_code;
/* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
uint8_t reg[1] = {0x80};
err_code = nrf_drv_twi_tx(&m_twi, vcnl4020_ADDR, reg, sizeof(reg), false);
while (NRF_DRV_TWI_EVT_DONE == false);
return (err_code);
/* Writing to pointer byte. */
reg[0] = vcnl4020_REG_PRODUCT_ID_REVISION_REGISTER;
err_code = nrf_drv_twi_tx(&m_twi, vcnl4020_ADDR, reg, 1, false);
while (m_xfer_done == false);
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(m_sample);
m_xfer_done = true;
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_lm75b_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL); //non-blocking mode...in blocking mode no twi_handler in provided and doen not uses interrupt
nrf_drv_twi_enable(&m_twi);
* @brief Function for reading data from temperature sensor.
static int read_sensor_data()
bool t;
uint32_t event;
ret_code_t err_code,err;
uint8_t reg[1] = {0x81U};
err_code = nrf_drv_twi_tx(&m_twi, vcnl4020_ADDR, ®[0], 1, false);
// if(err_code != NRF_SUCCESS) {
// return err_code;
/* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
// err_code=(0x13U>>1);
err = nrf_drv_twi_rx(&m_twi, vcnl4020_ADDR, &m_sample, sizeof(m_sample));
event = nrf_drv_twi_stopped_event_get(&m_twi);
t = nrf_drv_twi_is_busy(&m_twi); // true If the TWI driver is currently busy performing a transfer
while(m_xfer_done==false);
APP_ERROR_CHECK(err);
return (err_code);
return (m_sample);
ret_code_t rslt;
uint8_t out_t;
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_init();
// vcnl4020_set_mode();
while (true)
// nrf_delay_ms(500);
// do
// __WFE();
// }while (m_xfer_done == false);
rslt = read_sensor_data();
NRF_LOG_FLUSH();
this is what i am doing...the code is getting stuch at " while(m_xfer_done==false);"
t = nrf_drv_twi_is_busy(&m_twi); function returns true indicating that it is busy..why is nrf52832 is busy reading register... i am not understanding...will you help..
thank you for your reply
