NRF_ERROR_NO_MEM
I'm developing a FW with a lot of services and characteristics. Since I added the ANCS service, I have the "NRF_ERROR_NO_MEM".
Configuration : NRF51822_XXAC / S130 V2 / custom secure bootloader + DFU / Segger embedded studio / bootloader setting file to allow programing without DFU.
Section placement macro (Embedded studio) : FLASH_START=0x1b000 SRAM_START=0x20002008
I read a lot of things about this error : increase the size of the gatt table, adding "BLE_GATTS_VLOC_USER"...
Like explained on the migration guide, I checked the expected RAM size. The debug result is described below :
SDH:DEBUG:sd_ble_enable: RAM start at 0x20002008 SDH:DEBUG:RAM size should be adjusted to 0x5ff8 SDH:DEBUG:sd_ble_enable: RAM start should be adjusted to 0x20002008 :INFO:running nrf_dfu_settings_init APP:INFO:app_error_fault_handler : id=0x00004001, pc=0x00000000, info=0x20007f64 APP:INFO:err_code 00000004 in line 298 of XXXANCS/ble/ble_services.c APP:INFO:-> NRF_ERROR_BASE_NUM
I changed the SRAM size and attr_tab_size but after that, the application doesn't start like if the bootloader doesn't know where to find the application start address. Do I have to change something in the bootloader or something else that I missed?
Thank you
  • Yes, I'm able to debug when I keep the default configuration of our project.
    VS_UUID count : 3 Default table size (0x600)
    But when I change table size / SRAM start / VS_UUID, I have nothing on my RTT like if the app was not started.
    By adding ANCS I should change VS_UUID to at least 7 and adjust the table size but I'm stuck with this "starting issue".
    I just compiled a new bootloader in debug mode to have NRF_LOG but now I have a merging conflict (overlap)...
  • I found the issue. By changing the VS_UUID to 10 and adjust SRAM_START to 0x20002078 it's know OK. Thank you for your help
