As stated in standard the maximum data rate is 0.27Mbps. So is that is true for nRF8001 ??
Around 20ms, what Apple supports (from another post):
If you're working with Apple devices, it's useful to be aware of the fact that they have their own document detailing their recommendations for connection parameters. This document can be found here: https://developer.apple.com/hardwaredrivers/BluetoothDesignGuidelines.pdf
The reason I asked about the connection interval was that I couldn’t get your numbers to add up; at 20 ms you should be able to get a data throughput of about 8*20 bits * (1000 ms / 20 ms) = 8kbit/s Notifying, and 3 – 4 times that when receiving writes from the peer.
I paste a new reply from the Nordic employee who just corrected his reply:
Ole Morten44 minutes ago I just realized my calculations were wrong by a factor 8... If you read the above as kilobytes per second, not kilobits, they are correct. The throughput of nRF8001 is hence 0.67 kBps or 1-2 kBps (or 5-6 kbps and 10-16 kbps), given a 30 ms connection interval. Sorry for the confusion!
Now that we understand the theory behind the communications using BLE and the nRF8001 stack, I would like to state clear the theoretical and experimental numbers. I think it is a really valuable information for the community of developers:
nRF8001 Max Throughput: It can send only one packet and receive two-three packets for each connection event. Each packet contains 20 bytes.
With iOS, this becomes 0.67 kBps or 1-2 kBps (or 5-6 kbps and 10-16 kbps), given a 30 ms connection interval.
Receive packets in the iPhone every 32ms. 1 packet each 32ms -> 31 packets/sec -> 620Bps -> 4960bps
Please, if anyone has a counter example, feel free to add it to these numbers. Figures for Android devices are also welcome.
I'm trying to use this as a solution for transmitting SteamVR positional information to a mobile device. In my 20 byte packet im packing the following:
For a total of 13bytes out of the 20bytes allotted. My data is being fed from Serial USB and I'm transmitting this information to my mobile device as fast as I can. I've tried the follow:
All of which yielded roughly around 30fps of data received at the mobile device although my experience was running at 60+fps on my zenfone AR in a fairly empty VR scene.
I'm going to try to use wifi now. But it seems pretty consistent with the data provided above.
