License when reusing partial code from SDK examples
I have a little hobby project going on where I'm trying to make Nordic's old temperature broadcaster example work with the nRF52: github.com/.../
The project was originally released under the MIT license by Nordic, and I (and github.com/.../nrf51-ble-app-temp, which I also pulled some changes from) have kept the license as MIT.
Now I'd like to add support for fetching the battery value using SAADC, and was thinking to base my solution on the example in the ble_app_proximity example of nRF5 SDK 12.3.0, which has code for both nRF51 and nRF52. However, this example is released under the Nordic licence, which is a lot like MIT but not quite.
I wouldn't mind switching to the Nordic licence (after all, it's pretty close to the MIT license), but I'm not sure how well it would work when I have code from both Nordic and myself in the same file. The license requires that the disclaimer is kept, but the disclaimer seems to assume that the code in its entirety is written by Nordic. For example, the disclaimer starts with the following: "THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR". In this case, the software is also partially provided by me, so the disclaimer would both be misleading and incomplete; I also do not provide any warranties on the parts I wrote.
I considered working around this issue by keeping the ADC code in a separate file and keeping that under the Nordic license while the rest is MIT, but I'm worried future modifications will make the problem resurface later. What should I do?
I really wish the examples would just be plain MIT license, that would make it a lot easier to derive open-source projects from it. Considering how tied the code is to the way the SoftDevice and the hardware works, I doubt the extra requirements of the Nordic license are really necessary. Who would run this on a non-Nordic device?
For your reference, here is a copy of the Nordic license, taken from nRF5_SDK_12.3.0_d7731ad/examples/ble_peripheral/ble_app_proximity/main.c:
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
  • I really think Nordic is making a mistake with this license. This is effectively preventing the community from improving upon the examples and sharing them, which would only benefit Nordic. It would make a lot more sense to me if the examples were released with BSD 3-clause and the contents of the components folder were the ones restricted to run on Nordic devices.
    If someone is going to make a pirated nRF5 chip they'd presumably want to steal the drivers, so the license of the components folder would be the thing which makes sense to restrict. Are you really expecting someone to make a novel chip, with novel drivers, which happen to have exact API compatibility so they can reuse the nRF examples?
    Nordic seems to be planning to open-source the low level drivers but not the examples, which makes no sense to me. Please talk to your lawyers about this.
  • I do not think that this is a mistake, but rather a compromise that are beneficial for the community, our customers and Nordic Semiconductor. We do allow the code to be redistributed and as far as I know it is common practice to add your name to the copyright notice if you change files that are covered by a BSD license, see this.
  • OK, fair enough, the phrasing of clause 1 is actually identical between vanilla BSD 3-clause and the Nordic 5-clause (clause 1 is actually the only clause Nordic didn't modify), so adding my name to the copyright line should be OK. However, I'm pretty sure adding my own disclaimer below it is not OK, because that implies changing the license, so I'm still stuck.
    Had Nordic kept the original phrasing of "COPYRIGHT HOLDERS AND CONTRIBUTORS" from BSD 3-clause this wouldn't be an issue, but for some reason they chose to substitute it with an explicit "Nordic Semiconductor ASA" everywhere. I don't know why this choice was made, but I still think it was a mistake.
    As it stands, I don't feel comfortable making open-source contributions to any of the example code in the SDK, or even reuse parts of them. This kind of defies the point of having examples.
  • I agree that NORDIC SEMICONDUCTOR ASA AND CONTRIBUTORS would be a better phrasing. I do not know why only NORDIC SEMICONDUCTOR ASA was chosen by our lawyers, but I have reported this internally and then we'll see if we should modify the disclaimer or not.
  • softwareengineering.stackexchange.com/.../158011 suggests that I can dual-license an individual file by placing a different license for my modifications below the original license (which is pretty much what you suggested initially). This looks like it would solve my problem. The file will almost be more licenses than code, but that's OK.
    I would still have preferred if the Nordic 5-clause was phrased in such a way that I could just keep it as-is and not have to worry about this, though. Keeping your licensing as standard as possible makes it a lot easier for non-lawyers like myself to feel confident about making contributions. I know what the BSD, MIT and GPL licenses mean, and there are plenty of easy to understand explanations of them online. The Nordic 5-clause I have to interpret myself, and I'm honestly a lot better at programming than licensing law.
