twi_master_clear_bus fails
Calling twi_master_clear_bus() always returns bus_clear = FALSE. The IF statement is always FALSE even though both SDA and SCL measure high. All 18 SCL's occur in the ELSE but it fails, also. This has worked in the past but recently began failing every time. I tried other previously working firmware versions and they all fail, also. No known events have occurred to cause a hardware failure.
static bool twi_master_clear_bus(void)
{ uint32_t twi_state; bool bus_clear; uint32_t clk_pin_config; uint32_t data_pin_config;
// Save and disable TWI hardware so software can take control over the pins.
twi_state        = NRF_TWI1->ENABLE;
NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
clk_pin_config =
    NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER];
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] =
    (GPIO_PIN_CNF_SENSE_Disabled  << GPIO_PIN_CNF_SENSE_Pos)
  | (GPIO_PIN_CNF_DRIVE_S0D1    << GPIO_PIN_CNF_DRIVE_Pos)    // STD0, DISC1
  | (GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos)
  | (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos)
  | (GPIO_PIN_CNF_DIR_Output    << GPIO_PIN_CNF_DIR_Pos);
data_pin_config =
    NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER];
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER] =
TWI_SDA_HIGH();
TWI_SCL_HIGH();
TWI_DELAY();
if ((TWI_SDA_READ() == 1) && (TWI_SCL_READ() == 1))
    bus_clear = true;
    uint_fast8_t i;
    bus_clear = false;
    // Clock max 18 pulses worst case scenario(9 for master to send the rest of command and 9
    // for slave to respond) to SCL line and wait for SDA come high.
    for (i=18; i--;)
        TWI_SCL_LOW();
        TWI_DELAY();
        TWI_SCL_HIGH();
        TWI_DELAY();
        if (TWI_SDA_READ() == 1)
            bus_clear = true;
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] = clk_pin_config;
NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER]  = data_pin_config;
NRF_TWI1->ENABLE = twi_state;
return bus_clear;
