Spi_issues
Hello, I am using nRF SDK 12.2.0 , with nRF52832 on pca10040 hardware, and working with the example in examples/peripheral/spi/main.c to develop a driver for LIS2DE12.
Initially I was working on integrating a library, and found via Tera term (uart communication) that every other SPI byte output had a 0xFF appended . every other call to nrf_drv_spi_transfer(), The only modification I made was to change the SPI pins. Any ideas as to what's going on?image description(/attachment/aafcc184333cd473cba77b3053097890)
Thanks!
  • If you have started a transaction earlier then MAXCNT should not equal 0.
    Are you sure that you are looking at the correct SPIM peripheral? The screenshot you sent earlier from the debugger seems to imply that the SPIM module is not initialized at all.
    Best regards
