TWI locks on nRF51822 v3
hello,
i am experiencing issues with the TWI library on the smart beacon kit rev. 1.3.0 which features the v3 of the nRF51822. i had the same experience on the new nRF52840(preview devkit) but it is not happening as often there.
doing some research i stumbled upon several issues with the TWI driver/peripheral and also found out that there was indeed a lockup problem which, however, should be fixed with the current silicon revision.
TWI module lockup still present in nrf51822 v3-pan-56
TWI stuck and blocked [closed]
TWI issue ? [closed]
Possible bug: I2C stuck
we're using:
  • nRF5_SDK_12.3.0
  • nRF51822 (Smart Beacon Kit v 1.3.0), latest revision v3
  • nRF52840 (Bluetooth 5 preview kit)
the problem appears in nrf_drv_twi.c, line 561
while (twi_transfer(p_twi, &p_cb->error, &p_cb->bytes_transferred, (uint8_t *)p_data, length, no_stop))
one workaround mentioned in the other issues was to use the DMA mode - which is not available for the nRF51 (at least not in the SDK v12.3). are there any updates on that?
the device we're creating will be under heavy stress (vibrations, movement, etc.) so the I2C should be quite stable -- or at least we should be able to recover from issues w/o a restart (we'd lose the bluetooth connection).
any ideas on how to proceed? i really want to avoid using bit-banging.
  • that's exactly what's happening here. essentially the same thing happens on both the nRF52 and the nRF51 > except that i had to solder mini-wires to the beacon kit (the pads are extremely small). it only happens more often on the beacon due to the fact that only a little move in the wires will kill the transfer. on the nRF52 i essentially have to short them for the driver to fail.
    my question here is: does the peripheral give up here or is it just the blocking-wait in the driver?
    if its the latter - can i circumvent this by using the non-blocking version or are both using the same while-loop? if the non-blocking doesn't have this problem i can simply time-out the transfers and essentially implement some fault tolerance here.
    there's no way i get an approval for a prototype-PCB, so i'll have to live with dangling wires.
  • Hi Martin,
    The potential dead lock is SDK v13.x where we introduced an timeout in the while loop. Please have a look at the implementation in SDK v13.x:
      hw_timeout = HW_TIMEOUT; //10000
     while ((hw_timeout > 0) && twi_transfer(p_twi,   &p_cb->error, &p_cb->bytes_transferred,   (uint8_t *)p_data, length,  no_stop))
                hw_timeout--;
  • hello - yeah that's just it. i switched to app_twi and use it to implement a more robust communication with the I2C transactions going on in the background. should have done so in the first place i guess ;) otherwise the issue was really a mechanical one, guess it's not a good idea to have I2C or SPI on thin wires .. thanks !
