TWI HW producing shortened ACK clock pulse
Hi everyone,
we are trying to use the TWI interface of the nRF52832 to communicate with a TI BQ28Z610 fuel gauge, using the TWI driver of the nRF5_SDK_13.0. For the last few days we had seen always the same behaviour: when we were trying to transmit more than 1 byte of data, the device address as well as the first byte were transmitted correctly, the second byte however produced a NACK.
We've been able to narrow down the problem to the ACK clock pulse after the first byte. As you can see from the attached scope screenshots, the relevant clock pulse has circa 1/4 of the length of a normal clock pulse. While I'm assuming that this behaviour brings a technical advantage in most cases (since the shorter clock pulse frees the interface earlier for subsequent communication) it leads to problems with the BQ28Z610.
My workaround at this point is to use the deprecated bit banging methods from twi_sw_master.c. I've insterted a 5ms delay after the function checks for the ack bit to delay the SCL line going low again.
Now the question is, since we're not fully happy with not being able to use the TWI hardware driver, is there any way to lengthen the relavant clock pulse using the TWI hardware? Has anybody else experienced problems with that behaviour?
