HARDFAULT in mesh SDK ble_mesh_v0.9.1-Alpha access.c
I have the mesh serial example working with nRF51-DK (nRF51422). I am now trying to run the same code, via the nRF51-DK debug port, to a nRF51822 QFAC (32Mb) based board. It downloads and runs up to the following line where I get a HARDFAULT:
static void access_state_clear(void)
    memset(&m_model_pool[0], 0, sizeof(m_model_pool));
A break at this line shows the m_model_pool memory is allocated (it's static anyway) and accessible. Stepping over this line gives a HARDFAULT. What might be causing this?
The nRF51-DK (nRF51422) and the nRF51822 QFAC have the same memory maps so I am using the same build settings.
Simon
  • Hi Simon,
    This is very strange, indeed. Here's a some debugging questions:
    • Did you modify the example code in any way?
    • Are you using a different clock source on the external board, and is the softdevice (and mesh) initialized with the correct one?
    • Did you get a program counter address with the HARDFAULT? If so, could you provide the .elf and .map file along with the address of the fault?
    • Is anything of this running in an IRQ? Calling a softdevice function from an interrupt priority higher than the SVC will hardfault.
    I hope we'll get the problem solved soon.
    Best,
    Thomas
