Do Long delays in main loop cause problems? (possible brownout problem)
I'm using nrf_delay_ms to trigger a series of beeps though a speaker using PWM, but I seem to have intermittent problems with this when the device is connected.
Basically my Android app, connects to the "beacon" and write to a characteristic with a command that makes the beacon beep, so that it can be found by listening to the sound.
In the write data handler I use the app scheduler to call the findMeBeeps function
app_sched_event_put(0,0,(app_sched_event_handler_t)findMeBeeps);
void findMeBeeps(void)
	for(int i=0;i<5 ;i++)
		if (i!=0)
			nrf_delay_ms(250);
		beep(250);
the beep function turns on PWM to one of the pins, calls nrf_delay_ms and then turns pwm off again (and de-inits the PWM to stop the pin drawing any current)
So overall the 5 beeps take 2.5 second to complete and block the main loop while this is running.
Unfortunately, what seems to happen sometimes, is that I can't repeatedly send the command to play the beeps.
The Android app thinks its written to the characteristic, but the on_write function for the characteristic does not seem to receive the data.
Whats even stranger, is that sometimes I compile the code and it works fine, over and over again, and some other times, I compile the code and it will only play the beeps once.
So...
I don't know whether the problem is that I can't lock up the main loop for that long.
BTW. I have tried loads of other things to work out whats going on...
I tried just printing "Beep" to the debug terminal and this worked OK.
I also at one point changed the pin, so that I was not actually driving the speaker/buzzer, in case that was an issue, because the speaker/buzzer is drive via transistor and takes around 100mA. And at the time that seemed to work OK,
but as its all so intermittent, its hard to know if any of these changes yielded the result because of the change or just randomness.
Because currently I can beep 50 beeps of 50ms and thats also working perfectly.
But I"m sure tomorrow when I turn it on and compile in some more code it could go back to failing again
  • @RK
    Thanks
    You are right...
    Changing this has not fixed the problem :-(
    So I'll need to check if its a power /voltage issue.
    Its strangely intermittent.
    It can start to work, OK, even if I upload or reset the board multiple times
    But if I unplug and put it on its battery, it fails again, and does not start working again when I put it back on the PSU from the PC.
    On the PC I have a 1A regulator from the 5V, so it won't be short of current
  • I've now attached an oscilloscope across the battery on this device, and I think the problem is the CR2477 battery can't supply the necessary current to run the buzzer device that was fitted by the manufacturer :-(
    On the scope I see the voltage drops to 1.6V in the worst case, (below the minamum for the nRF51)
    The strange thing is,that the CPU side of the nRF51 seems to be running OK. Because after 30 second an application timer fires and my code disconnects so that the device does not get permanently left turned but idle. However, I do not get a disconnection notification either in the nRF51 code or from the Android end.
    iOS seems to be different. If I try to write to the device, iOS immediately notices even though the characteristic is WriteWithoutResponse.
    I will need to replace the buzzer with a lower current device, but I thought I'd post the resolution in case it helps anyone.
