HID get report from a mac not as expected
Hello again, This time I am trying to read HID reports using bluetooth to get the state of the caps lock. I know this should be super simple and its explained in the hid keyboard peripheral example using ble_hids_outp_rep_get. I am using a mac as a test machine and the report never becomes 0x02 (caps enabled).
Sadly I am unable to test it either using nRF connect due to the following: ˇgithub.com/.../4
Can anyone confirm that this is the case and if so, assuming it works on windows, explain why mac behaves this way?
Thank you, Yiangos
  • Maybe create a post here, and you can also contact apple direclty on this page.
  • Hello Again Sigurd, Thanks for the links, i created a report in the forum forums.developer.apple.com/.../257980 however I am not willing to pay 99$ to get code level support :P. I am just leaving the link here for future reference if the issue is ever solved.
    Yiangos
  • For anyone still looking into this a solution has not been found
  • I know this thread is 3 years old but I think I've found a solution to this issue if anyone else is coming across it.
    When using the ble_hids_keyboard example from the SDK I was experiencing the same problem, I would receive a report from macOS but the value of the caps lock bit wouldn't change. As I developed my firmware further I added a consumer control report to the hid device descriptor which meant that I needed to explicitly add a report ID to both the keyboard report and consumer control report. After adding the report ID to the keyboard report the capslock functionality started working on macOS. I haven't had time to fully test that this was the change that did it but I pretty sure it was.
    My report descriptor looks like this:
    static uint8_t report_map_data[] =
            0x05, 0x01,       // Usage Page (Generic Desktop)
            0x09, 0x06,       // Usage (Keyboard)
            0xA1, 0x01,       // Collection (Application)
            0x85, 0x01,       // Report ID (1) <---- !!!!This is the bit I added
            0x05, 0x07,       // Usage Page (Key Codes)
            0x19, 0xe0,       // Usage Minimum (224)
            0x29, 0xe7,       // Usage Maximum (231)
            0x15, 0x00,       // Logical Minimum (0)
            0x25, 0x01,       // Logical Maximum (1)
            0x75, 0x01,       // Report Size (1)
            0x95, 0x08,       // Report Count (8)
            0x81, 0x02,       // Input (Data, Variable, Absolute)
            0x95, 0x01,       // Report Count (1)
            0x75, 0x08,       // Report Size (8)
            0x81, 0x01,       // Input (Constant) reserved byte(1)
            0x95, 0x05,       // Report Count (5)
            0x05, 0x08,       // Usage Page (Page# for LEDs)
            0x19, 0x01,       // Usage Minimum (1)
            0x29, 0x05,       // Usage Maximum (5)
            0x91, 0x02,       // Output (Data, Variable, Absolute), Led report
            0x75, 0x03,       // Report Size (3)
            0x91, 0x01,       // Output (Data, Variable, Absolute), Led report padding
            0x95, 0x06,       // Report Count (6)
            0x25, 0x65,       // Logical Maximum (101)
            0x05, 0x07,       // Usage Page (Key codes)
            0x19, 0x00,       // Usage Minimum (0)
            0x29, 0x65,       // Usage Maximum (101)
            0x81, 0x00,       // Input (Data, Array) Key array(6 bytes)
            0x09, 0x05,       // Usage (Vendor Defined)
            0x26, 0xFF, 0x00, // Logical Maximum (255)
            0x75, 0x08,       // Report Size (8 bit)
            0x95, 0x02,       // Report Count (2)
            0xB1, 0x02,       // Feature (Data, Variable, Absolute)
            0xC0,             // End Collection (Application)
            //Consumer Control report
            0x05, 0x0C,       // Usage Page (Consumer Devices)
            0x09, 0x01,       // Usage (Consumer Control)
            0x85, 0x02,       // Report ID (2)
            0x09, 0xCD,       // Usage (Play/Pause)
            0x81, 0x02,       // Input (Data, Value, Relative, Bit Field)
            0x09, 0xB5,       // Usage (Scan Next Track)
            0x81, 0x02,       // Input (Data,Value,Relative,Bit Field)
            0x09, 0xB6,       // Usage (Scan Previous Track)
            0x09, 0xE2,       // Usage (Mute)
            0x09, 0xE9,       // Usage (Vol Up)
            0x09, 0xEA,       // Usage (Vol Down)
            0x09, 0x6F,       // Usage (Brightness Up)
            0x09, 0x70,       // Usage (Brightness Down)
            0xC0
     And my output report now looks like this:
        #define OUTPUT_REPORT_INDEX   0
        #define OUTPUT_REP_REF_ID     1//<----!!! This must match the report id specified in the descriptor
        #define OUTPUT_REPORT_MAX_LEN 1
        p_output_report                       = &output_report_array[OUTPUT_REPORT_INDEX];
        p_output_report->max_len              = OUTPUT_REPORT_MAX_LEN;
        p_output_report->rep_ref.report_id    = OUTPUT_REP_REF_ID;
        p_output_report->rep_ref.report_type  = BLE_HIDS_REP_TYPE_OUTPUT;
        p_output_report->sec.wr               = SEC_JUST_WORKS;
        p_output_report->sec.rd               = SEC_JUST_WORKS;
    I have no idea why specifying a report id would cause macOS to act differently but it seems it does.
    I hope this can help anyone who's having this problem!
  • Hey eekwils,
    Now having some more experience with macOS and its peripherals I believe that its caveats of the OS.
    For example there is another magic report you can send which will show your devices battery life in the macOS bar (like magic mice do etc).
    Thank you for replying to my 3 year old question! I deeply appreciate it:)
