NRF24LE1 Communication
Hi all! I am approaching this with pretty much zero experience but what I'm trying to build should be a piece of cake for you so any help, example code, advice will be appreciated.
The idea is to build a simple notification system. The RX is connected to a 3V coin cell through an on/off switch and couple LED's. If switched on, LED blinks once and the RX enters deep sleep mode and wakes up when a signal from a TX is received. When RX wakes up, LED's blink until RX is switched off. If switched off/on, RX resets, enters deep sleep and waits for a signal.
The TX is connected to a 3V power source. As soon as TX switches on, it sends a signal to RX and RX wakes up. The TX repeatedly sends signal to RX for 2 minutes and enters deep sleep if not switched off.
I'm using 2 x NRF24LE1, Q32, Keil software, mpro burner. I have programmed a device to blink a LED (Hello World) and 2 devices to communicate with "enhanced_shockburst" example, but that is as far is I've got. Trying to add deep sleep and wake up on pins resulted in nearly burning the chips.
Maybe someone has done/made something similar and can help even a bit?
Send help to NRF24LE1 street. Thank you in advance!
