I would like send serial data in both directions (like by RS-232) between BMD-300 Evaluation Kit and BLED112 dongle.
I'm a beginner on this subject, so I'll ask You for an simplest example project (c++) that allow do this.
Best regards.
Marogo
Best regards.
Marogo
I tried use the Code::Blocks environment to compile code examples from SDK. Which compilator I should use to create Windows console application? Now I have selected default compilator "GNU GCC Compiler" (MinGW), by it generated many errors. Maby it's not valid compilator? Sorry, I'm beginner in C programming. :(
nRF5 SDK examples work with GCC pretty well, just make sure you follow the tutorials and it's safer if you use exact version of gcc-arm-eabi-nano toolchain as mentioned in SDK release note (each version uses slightly different GCC version, mainly to keep up with GCC updates).
